Black smoke
Old Apr 20, 2007 | 01:09 PM
Dave86's Avatar
Black smoke
I have an 86 toyota truck with a 22r and it makes black smoke and idles very rough but when it warms up it idle decent and still makes black smoke
Old Apr 20, 2007 | 01:26 PM
thook's Avatar
Your engine is running rich...too much fuel and/or not being burned efficiently. It could be a number of things, though. Do a search. There are lots of threads about black smoke.
Old May 14, 2007 | 11:10 AM
sh0kk86's Avatar
did you ever get this fixed? i have an 86, and the exact same problem.
ill continue searching, then ima go outside and messaround with the carb.
Old May 14, 2007 | 12:09 PM
tssievert's Avatar
search for aap
Old May 14, 2007 | 04:41 PM
drew303's Avatar
clear the grime off the float window on the front of the carb and look where the fuel level is sitting when you start it up.
If you cant see a line then theres to much fuel in the carb. This could be a lot of different things going on inside the carb that could cause this however the prime suspects are the floats themselves somehow not floating (heh) or a power piston or power valve sticking. Lots of things.
Least you can do is take the carb off and clean it out as best as you possibly can with forced air and carb cleaner and throw on a new fuel filter and air filter make sure the air filter is sealing top and bottom.
We're fighting the carb on our 87 with 212k miles. I rebuilt it but gunk from either dust or the fuel tank has been making its way into the carb and clogging things.
The only part I wasnt able to get apart was the jet/valve (whatever its called) that the float needle pushes up into. The screen in there could be damaged or deteriorating.
Anyways, black smoke means to much fuel not enough air.
Old May 16, 2007 | 01:59 PM
sh0kk86's Avatar
i took it apart yesterday, and used about a can of carb cleaner, and all last night it was running great. This morning i start it up, and it has black smoke again.
i havea question as well, when you look at the top of the carb it has the 2 holes, are the lids open all the way on yours? on mine the passenger side one is open, the driver side is almost closed. would it be safe to mess with that?
Old May 16, 2007 | 02:10 PM
hross14's Avatar
It sounds like you have one of those rare diesel toyota 22r. smokes black, runs rough--then smooths out as it warms up! Just kidding--couldnt hep myself. Good luck
Old May 16, 2007 | 02:39 PM
SwampThing's Avatar
Thats one thing I loved about my ol dodge 3500. Had a bumper sticker that said I Smoke Suddenly For Tailgators. Nothin like burning a ricer and leavin em in a cloud of smoke.
Old May 17, 2007 | 12:29 PM
sh0kk86's Avatar
well i dont really mind the smoke itself, just the fact that its sucking gas really fast. i was checking the manual earlier, and it said theres a hose to pinch it when the truck is warm till it dies, then start it up and see if it sprays gas?
does this really tell if i need to replace the aap diaphram?
Old May 23, 2007 | 02:58 PM
sh0kk86's Avatar
any help guys?
shouldi just go for a carb kit from napa and a fuel filter?
or what? i want to get this running right.
Old May 23, 2007 | 03:00 PM
gilby4runner's Avatar
if you rebuilt it then it should solve your issues... with a carb that old it wouldnt hurt to just go ahead and rebuilt it
Old May 23, 2007 | 03:03 PM
sh0kk86's Avatar
I think im going to get a new float as well. hope this will solve my problems...
i want to work on it so bad, but i have to go to work in a bit, and tomorrow is graduation all day, so friday morning im going to work on it.
Old May 23, 2007 | 03:41 PM
sh0kk86's Avatar
secondary diaphram or primary diaphram
for the aap
Old May 23, 2007 | 04:21 PM
notanymore's Avatar
i loled really hard at that
Old Nov 29, 2013 | 11:29 AM
BCYOTA's Avatar
Exclamation 87' Toyota Pickup 22R idles rough and has black smoke. Solutions?
A few months ago I had my carb rebuilt. It ran great for awhile and after I have moved away from the local "Carb Shop" it is now idling rough and has black smoke. I called the "Carb Shop" and he told me that the AAP may have gone bad, already? I thought. He explained today's fuels can do it and how this is the most common problem. He had me pull the vacuum hose from the AAP and see if it was sucking gas in and if so plug it off. I did and it was sucking in fuel but it did not stop the rough idle but it did stop the black smoke. I did not know if I needed to plug off wear the gas was coming from nor did I have the means at the time- Would this fix the idle problem, I wouldn't think so but I'm not sure. If anyone has any helpful suggestions I'm all ears. Thank you.
puddlepirate
Jul 30, 2016 06:29 PM
dzldust
7
Oct 6, 2015 05:39 AM
dbollier123
Sep 29, 2015 05:23 PM
whiteyota93
Sep 29, 2015 02:31 PM
charlie_fong
Sep 27, 2015 10:06 PM
