Engine swap from 90 to 92?
Old Apr 18, 2007 | 02:45 PM
mike92runnerSR5's Avatar
Does anyone know if a 90 engine would be a direct swap into a 92? Assuming they are both 3vze auto 4x4. Will the elec. connections, power steering, alternator all work the same? Thanks for info. I would think the motor mounts might be differen't. How about the tranny?
Old Apr 18, 2007 | 02:56 PM
doug's Avatar
if both motors are the 3vze evething will bolt right up
Old Apr 18, 2007 | 02:58 PM
Hmm that's what I thought. I just need to make sure the 90 is an auto right? Thanks.
Old Apr 18, 2007 | 03:01 PM
Anyone know how far back the V06 HG recall went? to 90? When did they change from the abestos HG to the one that blows? hehe
Old Apr 18, 2007 | 03:16 PM
thook's Avatar
You may have some wiring harness issues. Not sure when the throttle bodies changed over, but there may be a difference there. (i.e. TPS)
The changes weren't major. Any issues should easily be solved.
Old Apr 18, 2007 | 03:18 PM
thanks thook..how about motor mounts?
Old Apr 18, 2007 | 03:25 PM
stumprunner's Avatar
Motor mounts are the same
Old Apr 18, 2007 | 03:31 PM
thanks stump...anyone know if the 90 had the good HG?
Old Apr 18, 2007 | 04:46 PM
thook's Avatar
The recall was from '88 to late '96, I believe. Try calling the dealer and see if they can track the motor if it was done already.
Old Apr 18, 2007 | 06:25 PM
The 90 runner has 142K with a rusty chasis...think it's worth $500 just for the engine to swap into my 92?
Old Apr 18, 2007 | 06:27 PM
92 has blown HG and valve probs..
Old Apr 18, 2007 | 07:09 PM
Stomis's Avatar
FYI they never got the 3vze out with an asbestos HG. They banned asbestos while the engine was in design. Probably would be a much better engine now adays was it not for that.
Old Apr 18, 2007 | 07:12 PM
hmmm..I read one post that they were installed from 88-mid 90 in the 3vze's during that span.
Old Apr 18, 2007 | 07:20 PM
breknraj's Avatar
My '90 P/U was not part of the recall. I was told that it was because it DID have asbestos head gaskets. I got about 135k out of it before it siezed from different problems (of my own doing - nothing that Toyota did).
I've never researched it, but I surmise that they may have been building the engines in a couple of different places, and one place was getting asbestos gaskets, and the other wasn't - in anticipation of the ban. In any case, I'm sure that they were using up the asbestos gaskets while they still could.
Old Apr 18, 2007 | 07:55 PM
Stomis's Avatar
Hmmm I've read quite a few threads on here saying the engine was designed to run like a champ with an asbestos head gasket but it got outlawed before it hit production.
Old Apr 18, 2007 | 08:50 PM
thook's Avatar
So, the '92 motor is shot and you have the option to buy the whole '90 4rnr for $500...motor included? How much for just the motor?
Old Apr 19, 2007 | 04:06 PM
continuing...actually the seller is asking $650 for the 90...the whole rig, but I think I might be able to talk him down..deal or no deal?
Old Apr 19, 2007 | 04:37 PM
breknraj's Avatar
If the overall condition is OK, and you have space, I'd say do it. You could probably recover your costs, and then some, by parting the rest out.
Old Apr 19, 2007 | 04:42 PM
thook's Avatar
Those were my thoughts. Or keep the spare parts for yours. It doesn't hurt to have some backup if/when things break....which they seem to do.
Old Apr 19, 2007 | 05:07 PM
yea...thing is if I swap the motor I think I would still need to replace some things...timing belt, water pump..main seals..etc. valve adjust maybe, valve cover gask...tune up parts...diff. color than mine..blue/blue..mines black/gray..can't use any interior stuff
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
