The starter again!
Old Apr 19, 2007 | 03:36 PM
CanadianToy's Avatar
The starter again!
Hi everyone,
I know this has been covered over and over again but I am stumped!
I have the famous "click" "click" when you turn the key.
I do have the fsm and I did a lot of reading to get to this point.
I'm on my 3rd starter, this last one a new "rebuilt" from a dealer on ebay.
The tests with this last starter:
11.76 volts at the control connector under load.
11.40 volts at the starter main terminal under load.
I've replaced the contacts in the starter
I've cleaned pos and neg cables
I've changed the pos and neg cables
The only way I can get the starter to work is to use a wire directly between the control contact and the battery but my wire gets hot. I measured 16.7 amps drawn through the control wire.
Not sure what to do next...
CT
Old Apr 19, 2007 | 03:40 PM
bob200587's Avatar
stumped me....It's almost always the contacts. Unless there's something else. Ignition switch or something like that could be the culprit.
Old Apr 19, 2007 | 03:55 PM
carose725's Avatar
if i were you i would try the painless wiring hot shot relay. i changed my starter about a month ago due to the clicks, and four days later it was clicking again. i bought the hot shot relay kit about two weeks ago. after a very easy install my runner has started every time. its about $35 shipped but its much better than a starter install and has worked perfect so far to solve my clicker
Old Apr 23, 2007 | 07:44 PM
Is this relay sealed? How does it work if you cross water?
Old Apr 23, 2007 | 08:26 PM
JEDI87's Avatar
Mine did that even after I bought a new starter. I found that the single solenoid wire wasn't making good enough contact, was a little loose. I cleaned it (wire side), clamped the connector a little tighter and it works great.
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
