PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 [218] 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. brakes went bye....ut oh
  2. axle shaft rear
  3. calibrating my speedy meter
  4. Whining noise when I turn off engine
  5. Really bad exhaust smell
  6. knocking from the engine or bellhousing
  7. My 88 blew the head gasket
  8. Extra Lighting - So many options
  9. I know injectors tick BUT
  10. Yakima SST towers and 2nd gen.
  11. exhaust leak in my 88 yota
  12. Bilstein 5150 shocks??
  13. Clos 88 Runner Updates
  14. front lift
  15. engine runs better
  16. fixed my axle seals not another problem needs to be fixed... a little help please
  17. stealership woes!!! need assistance
  18. Need to replace this part, what is it?
  19. Poor man's Herculiner (real poor)
  20. are bracket lifts a good idea?
  21. My next mod...Its like I have a new one every week!
  22. Any details and specifications on the 1994 22re auto diff?
  23. 87 4runner timing problem
  24. Horrendous gas mileage
  25. 94 toyota pu 22Re
  26. c clip front axle help!
  27. what is this?
  28. Ifs?
  29. Clutch trouble
  30. Today My 4runner is ALIVE!
  31. Cold Starting Problems for my 94
  32. More pics of my truck!
  33. Old school FJ style grill
  34. How do you guys fill your manual transmissions?
  35. specs for rock sliders
  36. 3vze rebuild
  37. holy driveline PITA
  38. Where is the speed sensor on the trans
  39. '94 Pickup Heater Core Removal
  40. Intermittant BRAKE! light coming on
  41. 4" lifted leaf springs
  42. power steering question
  43. Wiper arms for 4Runner
  44. anybody know where to get heater core hard lines?
  45. New pics of 3 MINT 1st gens
  46. Lets put together a REAR disk setup..using all yota parts
  47. 1987 toyota 22r 4wd (need help ASAP)
  48. A few new pics of my truck
  49. Cutting the fenders..... Please help
  50. New guy here with some electrical & vacuum ???
  51. Doing rear seat swap. Need some bolt size info.
  52. Trouble With Codes
  53. Took some pics
  54. where are the terminals
  55. Idler Arm Replacement Problem
  56. Will 8" spline 3rd member fit fit a '91 4Runner?
  57. Marlins rollcage? who runs it in the pickup?
  58. hella 500s on the bumper...install tips.
  59. Why dont they seem brighter? hella500 bulb swaps
  60. Where do you store you're highlift?
  61. speaker box for xtra cab pickup??
  62. 33x10.50
  63. Exhaust question
  64. 1988 Tps
  65. Heater Valve Replacement Options
  66. light bar?
  67. Intake Silence Removal Mod for $10.99!!!!
  68. Idle fluctuation
  69. WHAT oil for transfercase?
  70. EGR valve
  71. 3.0 Exhaust manifold modification. Tell me what you think
  72. Idler pully
  73. BJ spacers
  74. the mystery of my runner not running
  75. what size wheel will fit my '88
  76. toyota pickup scanners for diagnostics?
  77. Feeler- Trade door panels for windows for manual ones?
  78. Biggest tires with b/j spacers?
  79. Car isn't running any ideas? 87 4runner
  80. What say ye! Engine options.
  81. Accounting error in my favor! $1500 to spend on toys
  82. 93 p/u w/ 3.0 sputtering and hesitation issues
  83. Lift instructions
  84. Lookin for a sweet 1st gen?????
  85. Front-End Regearing????Question????
  86. Injectors
  87. Rust repair on 2nd gen Xtra cab pickup
  88. I need a little help diagnosing
  89. 211 page Toyota FAQ document
  90. Spark plug wires
  91. 94 moab rack
  92. Speaker ideas?
  93. 22re wiring harness
  94. 22RE starter issues
  95. New half-axle - no go backie !
  96. PickUp to Tacoma
  97. Smittybuilt Winch? need info
  98. New Issue, just looking for ideas what it could be
  99. TPS vs. Timing
  100. Now I have a problem!!!
  101. 86 4runner for sale in vegas... 700
  102. oil cap idle change????
  103. Who makes a bumper like this?
  104. gas door
  105. Tjm t13
  106. well its been a ruff week
  107. Can i only re-gear the rear?
  108. Acquired a '95 4Runner 3VZE, bad MPG + a few ?'s
  109. 1992 w/ 12,900 miles!! CRAZY!
  110. IFS Swaybar... good or bad?
  111. Cold air intake on Ebaymotors
  112. Manual to Power Window Swap?
  113. inclometer
  114. Two quick projects today. Braces
  115. Some general questions about replacing tie rods
  116. unbolting balljoints - does it ruin alignment?
  117. new shocks YAY!
  118. 3VZE Vacuum lines
  119. Top hoist ??? for 86 4Runner
  120. My cheap 2.5" exhaust on the cheap
  121. Same style transfer case. Different shift rods
  122. what to do with my 1995 4 runner?
  123. Diesel swap question
  124. oil relocation kits
  125. Used door pwr lock/window plugs
  126. anyone know the limits of a 22RE? debating a build or swap
  127. horrible squeek front end
  128. What is your weekend project?
  129. accident suck - need frame/steering checking help
  130. Looking for some tire opinions
  131. I am Steet Legal
  132. e-brake help
  133. Need help removing clutch pedal assembly
  134. interior parts from a taco to a 88 pickup
  135. Brake Upgrade?
  136. Finishing up the 3.4 swap
  137. 3.0 overheating...help
  138. Ways to tell a Blown Headgasket
  139. Steering column, best way to undo
  140. Upgraded My Shocks
  141. crazy spedometer question/ headlamp broken harness?
  142. EGR Valve Replace
  143. need help on photoshoping some pics
  144. Got my brush guard mounted
  145. 1994 SR5 22RE Daily Driver Bore Limit?
  146. short throw shifter?
  147. rear axle removal 101
  148. Who else makes sliders?
  149. I redid the ENTIRE interior...check it out fellas!
  150. tools needed to install a lockright
  151. fuel smell wont go away
  152. Auto to Manual 5sp swap - Complete!
  153. Help me decide on which 2 wheels!!
  154. Engine Conversions
  155. RoundEyes H4 headlight upgrade installed
  156. Paint help!!!!! auto painters please look! window tint aswell
  157. spare tire mount
  158. In need of seats....
  159. ball joint spacers and torsion bar lift????
  160. Whats the best cam for 22re upgrade???
  161. new to yotatech!
  162. Hi and tbar clunk question from new guy
  163. Electric lockers __Yea or Ney__ ? ? ? ?
  164. steering gear box?
  165. Anybody run HELLA500 FF's?
  166. flexalite xtreme 180 on 3vze
  167. EGR Question
  168. front brake lines refuse to bleed '89 half ton
  169. Some new projects....just an update
  170. motor wont turn after install
  171. Please help - 5sp stuck in reverse
  172. 93 runner alighnment
  173. New radiator question?
  174. What angles for 22re?
  175. 95 4runner running boards, front valence and rear bumper corners
  176. need pictures of air intake on 1990 toyota pickup 3VZE engine
  177. 13" steering wheel - anyone have driving issues?
  178. Need part # for 85 2LT diesel STARTER!
  179. Broken Exhaust Crossover?
  180. 302!!
  181. Injectors Problem
  182. 4" Speakers, any good links?
  183. Charcoal Filter?
  184. yet another leaf spring Question.
  185. shift ?
  186. How is lugging bad for motor?
  187. Bad Alternator?
  188. Blinky A/C lights
  189. Help me put this idea together....
  190. Old 3rd members?
  191. Brake calibers
  192. Sylvania Silverstar Ultras 9004/SU
  193. what are these worth?
  194. Bad Wheel Wobble
  195. Help me choose an interior color
  196. No Lift 33" on my 91
  197. what would be a fair labor cost to have my clutch replaced
  198. speedometer woes....
  199. Advice needed: 92 4runner purchase (blown head gaskets)
  200. Need advice with rust repair
  201. all pro transfer case parking brake, speedo?
  202. how deep do I have to go for a heater core, '87 4runner
  203. FJ style hood scoop on a 2nd 4Runner?
  204. replacing clutch... quick qustions
  205. Great news! My frame is bent!
  206. A/C Light is off...but a/c works??
  207. Need advice/opinions on 22RE condition
  208. Coolant Leak 3.0
  209. I have a rear axle question
  210. PCV Valve necessary
  211. Easy ISR tube?
  212. control arm swap?
  213. Body Lift a good idea?
  214. a question... turbo related...
  215. Need new steering wheel & stabilizer
  216. 89-95 Front Clip Removal? Xtreme 4x4 Toyota SAS
  217. Will this work with my truck????
  218. my front end has some slop...
  219. 88 4runner REDUX
  220. Car Cover for 4Runner, suggestions?
  221. 88' 22re Pickup exhaust
  222. Any body in Lewiston Idaho area want to go wheelin?
  223. Removable Top Bolts?
  224. Bored...so heres some pictures of the yota.
  225. downey skid
  226. can't seam to get my dash out, 87 4runner
  227. Rhino lining on body of truck/4runner
  228. Weird Brake problem
  229. Bucking on Light Acceleration
  230. Power Steering Geerbox Leak
  231. Pinion Bearings Loose-Tighten or Replace?
  232. Spark Plug Mayhem , Another Question
  233. oem or aftermarket pads? Help
  234. Question about bogging on 3VZE
  235. possible to replace the liner under hood?
  236. craigslist seattle, brush guard for 2nd gen
  237. Blown engine need ideas
  238. Disk removal for 95 toyota t100 4x4
  239. 92 3vze - BTDC timing - what's acceptable?
  240. rear pinion seal
  241. Project: I want my 88 4runner back!
  242. will be purchasing a 88 truck
  243. Yup.....CV Boot time
  244. Help Purchasing 93 Deluxe SB Pickup (3.0)
  245. shifter knob ?
  246. muffler replacement
  247. Why is my timing jumping all around?
  248. FabTech brush guard installed
  249. Spark Plug Re-Tap Problem , HELP
  250. mud got me grounded.
