Trouble With Codes
Old Oct 9, 2007 | 02:24 PM
naadomail's Avatar
Exclamation Trouble With Codes
As many of you know, I have recently invented/equipped the "Yellow Hose Of Texas" mod on my runner. In the process I accidentally started my truck without the MAF sensor plugged in. Problem is, I cannot get the codes to clear. I pulled the EFI relay and left it out for 15 minutes, put it back in and they were still there. I left the EFI relay out for 2 hours, still there. Any ideas??
Old Oct 9, 2007 | 02:26 PM
fillsrunner4's Avatar
undo the battery and turn the key a few times and plug the battery back up. try that
Old Oct 9, 2007 | 02:34 PM
olharleyman's Avatar
x2 undo the battery and rub the cables together then hook battery back up Rubbing the cables together should clear all power and inturn clear the codes stored. It will also make your truck relearn your driving style and adjust the computer to it.
Old Oct 9, 2007 | 02:37 PM
n4ynu1010's Avatar
CEL Code
Maybe you have a bad wire or MAF Sensor and every time you key the thing it is regenerating code , EFI removed for 30 secs should be enough , and battery disconnected for a few minutes as well , may prove worthwhile to try the "Turn on Ign Key" I guess for GP but ahould have cleared
Old Oct 9, 2007 | 04:32 PM
mr toytech's Avatar
you should remove the efi fuse, not the relay.30 sec should do it unless there is an actual problem.
Old Oct 9, 2007 | 04:59 PM
naadomail's Avatar
Ended up touching the battery cables together. Worked fine codes are clear and we'll see if they pop up again. Thanks all. Also the driving dynamics did change a little, barely noticable. Not sure if it was for the better or worse, but different none the less.
Old Oct 9, 2007 | 11:01 PM
thook's Avatar
Bear in mind, sometimes if one is messing the AFM harness a lot...taking it on and off.....the wires/terminals can work themselves loose from the connector and not get a connection when you plug the connector back in. So, if ever in doubt, it's a good thing to check for.
Old Oct 11, 2007 | 06:33 PM
n4ynu1010's Avatar
Broken Wire
Very few take the time to suspect that "King of Illusion" .............the broken wire within the insulation hidden and all the while they pull their hair out and check all the controls again for the 3rd time .
Old Oct 11, 2007 | 06:52 PM
Targetnut's Avatar
Do you have a capacitor installed for your stereo?
If so it will store enough charge to keep your ECM memory alive with the battery disconnected for quite some time. Touching the cables together would have discharged it.
Old Oct 12, 2007 | 05:01 AM
n4ynu1010's Avatar
Codes
Well when you reset the ECM it will go into a re-learn mode for a while so the motor running/idling should improve over a bit of time driving , hope your code free !!
some drunk guy
Aug 3, 2021 06:09 PM
Longbed 90
Mar 11, 2019 12:38 PM
Firefightersink15
Nov 23, 2015 10:32 PM
Armstrong486
Sep 19, 2015 12:37 AM
128keaton
Sep 3, 2015 05:09 PM
