Trouble With Codes
As many of you know, I have recently invented/equipped the "Yellow Hose Of Texas" mod on my runner. In the process I accidentally started my truck without the MAF sensor plugged in. Problem is, I cannot get the codes to clear. I pulled the EFI relay and left it out for 15 minutes, put it back in and they were still there. I left the EFI relay out for 2 hours, still there. Any ideas??
undo the battery and turn the key a few times and plug the battery back up. try that
Originally Posted by fillsrunner4
(Post 50635404)
CEL Code
Maybe you have a bad wire or MAF Sensor and every time you key the thing it is regenerating code , EFI removed for 30 secs should be enough , and battery disconnected for a few minutes as well , may prove worthwhile to try the "Turn on Ign Key" I guess for GP but ahould have cleared
you should remove the efi fuse, not the relay.30 sec should do it unless there is an actual problem.
Ended up touching the battery cables together. Worked fine codes are clear and we'll see if they pop up again. Thanks all. Also the driving dynamics did change a little, barely noticable. Not sure if it was for the better or worse, but different none the less.
Bear in mind, sometimes if one is messing the AFM harness a lot...taking it on and off.....the wires/terminals can work themselves loose from the connector and not get a connection when you plug the connector back in. So, if ever in doubt, it's a good thing to check for.
Broken Wire
Originally Posted by thook
(Post 50635840)
Do you have a capacitor installed for your stereo?
If so it will store enough charge to keep your ECM memory alive with the battery disconnected for quite some time. Touching the cables together would have discharged it. |
Codes
Originally Posted by naadomail
(Post 50635512)
