spare tire mount
Old Oct 4, 2007 | 06:27 AM
Robert m's Avatar
spare tire mount
does anyone know how much weight the under the bed, stock spare tire cable mount can hold?
Old Oct 4, 2007 | 02:14 PM
TORTIS's Avatar
the weight of the tire and a couple of kilos for sure. well,that is what i have been told. that is my story and i am sticking to it.
Old Oct 4, 2007 | 03:30 PM
justinking060310's Avatar
I can't help but laugh at that one Tortis!!
Old Oct 5, 2007 | 12:33 AM
sh0kk86's Avatar
anyone with pickups mount there spare tire anywhere but under the bed? I will be getting some 33's soon and not sure if theyll fit, or if i should find a way to mount it in the bed.
only problem would be getting my bike in the back...
Old Oct 12, 2007 | 06:48 PM
lphillippi's Avatar
Universal truck spare tire mount - patent pending
I made these to bolt my spare tire laying down flat in the bed. Drill two holes in your bed and push bolts up through the holes in the bed and wheel. My tires are 31x10.5 and the bolts I used are 6.5" and they go through the 1/4" plate. If your 33s are wider than 10.5" you might need to get longer bolts. Don't bother looking for a metric bolt, you won't find it and don't need it. Buy a standard bolt and put locking lug nuts on both bolts.
Patent pending. All lefts reserved.
Old Oct 12, 2007 | 06:59 PM
rowdy235's Avatar
personally i was looking for an alternate location to mount the spare as well. Crawling under the truck in the rain and mud to get the spare out is not fun. Especially on a 2wd.
Old Oct 12, 2007 | 07:31 PM
Fizboy's Avatar
Don't know if this will help but I have a 92 4-runner with a 33x10.50 AT stuffed under the back. I had to bend the original guides that center the tire a little but it fits. However it will be moved as soon as I get a bumper with a tire carrier on it to make way for the auxiliary fuel tank.
Old Oct 12, 2007 | 07:43 PM
Reaper's Avatar
I came up with something like this cost me $30 to make
I lose a little bed space but I don't have craw in the mud to get my spare out.
Old Oct 12, 2007 | 07:45 PM
ozziesironmanoffroad's Avatar
love the in bed tire holders, but theres one thing i dont like about them.... how are you supposed to haul your ATV or dirtbike back there? (or.. for that matter.. where do you put your wife when shes being a PITA?)
Old Oct 12, 2007 | 08:47 PM
4Crawler's Avatar
I can run a 33x10.50 underneath my '85:
Although now I use my rear carrier:
Old Oct 13, 2007 | 02:55 AM
TORTIS's Avatar
4crawler, what is that black and white pipe on right lower side.
Old Oct 13, 2007 | 04:51 AM
88-surf's Avatar
is it in the 1st pic .it looks like a jack handle?
Old Oct 13, 2007 | 08:12 AM
lphillippi's Avatar
I originally drilled a hole in the plate and was planing on welding a bolt on the under side of the bed to hold the mount in place when changing the tire. The mount doesn't exactly fall out easy and there is a cross member under the bed that I can rest the plate on to keep it from falling out when the tire isn't attached. I have a dirt bike and the tire leaves plenty of room for the bike, cooler and everything else.
Old Oct 13, 2007 | 10:50 AM
n4ynu1010's Avatar
Tire too big , throw it out and get better gas mileage
Old Oct 17, 2007 | 08:49 AM
tj884Rdlx's Avatar
that IS a jack handle. you can see the orange jack (under the tranny maybe) in that same pic.
has anyone seen this Hummer H2 tire carrier? It looks like a nice compact swingaway style. their price seems steep but i like the single hinge design
http://images.google.com/imgres?imgu...%3D1%26hl%3Den
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
