Will 8" spline 3rd member fit fit a '91 4Runner?
Old 10-09-2007, 12:34 PM
Kaimuki4Runner's Avatar
Found a seller with 4.88 gears. He's also selling an '85 straight axle so I'm assuming the 3rd member also came from an '85. My 4wd runner has the 3.0 slow, 5 speed w/4.10 stock gears. Is the 3rd member a "straight, no problems, nothing to worry about" bolt in to my truck? Is there anything I should be concerned with besides the fact that I cannot shift into 4wd? Thanks guys!
Old 10-09-2007, 01:08 PM
881stGenRunner's Avatar
Yes no problems whatsoever.
Old 10-09-2007, 02:16 PM
tc
tc's Avatar
http://home.4x4wire.com/erik/diffs/
Yep, no problem. It's a 4cylinder third, so SLIGHTLY less strong than your V6 third, but IMHO not by enough to worry about.
Old 10-09-2007, 04:45 PM
AxleIke's Avatar
I think 4cyl vs 6cyl isn't really an issue until you start talking about either a lot of power, or monster tires. I doubt the 3.0 is going to put out enough to break it. They use the same frontend.
Old 10-09-2007, 05:11 PM
mt_goat's Avatar
Maybe...maybe not. Some V6 autos came from the factory with 4.88s.
Old 10-10-2007, 08:59 AM
Thanks for your responses guys. One of my concerns is that it's 20+ years old. Is that something to worry about? Also, was 4.88 available as stock?
Old 10-10-2007, 09:46 AM
BLKNBLU's Avatar
Not on an '85. If it is in fact from an '85, it's been re-setup at some point.
Old 10-10-2007, 09:55 AM
spaceycayce's Avatar
Yeah 4.88's come with some 3.0 v6's. Mine had them stock. Only problem is IIRC if its a stock 4.88 third you can only fit factory toyota gears in these. I'd hold out for a 4.56 or 4.10 third (Our local pick and pull has a ton of these) unless you plan on staying with 4.88's. I had to get a 4.56 for my setup to fit the 5.29's. Otherwise it all will fit quite well. Toyota parts are quite interchangeable. Again others feel free to correct me if I am wrong.
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
smiley52
07-11-2015 05:16 AM
icentropy
07-09-2015 02:12 PM
Quick Reply: Will 8" spline 3rd member fit fit a '91 4Runner?
