gas door
Old Oct 7, 2007 | 08:18 AM
86blue4runner's Avatar
gas door
hey yall,
pulled up to the pump the last night, pulled the gas door pop and heard something hit the ground. sure enough i walked around the other side and my gas door was sitting there on the ground. how can i get the door back on there WITHOUT welding.
thanks for any input
Old Oct 7, 2007 | 08:31 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
lets see some pics of the carnage so we can see exactly how it broke off...
Old Oct 7, 2007 | 09:11 AM
DeathCougar's Avatar
get a used one from a wrecking yard. Once they are broken, they are too flimsy to ever go back together.
Old Oct 7, 2007 | 09:50 AM
TORTIS's Avatar
i had to tig weld mine back together on the bottom bracket. bought a parts truck and then swaped it out, but it was working fine.
Old Oct 7, 2007 | 03:50 PM
heres some pics. you probably cant tell anything though.
Old Oct 7, 2007 | 04:27 PM
pepsibluefloat's Avatar
x2. cant cost to much for a used one, then have it painted to match...
Old Oct 7, 2007 | 04:38 PM
TORTIS's Avatar
thats where mine broke.
Old Oct 7, 2007 | 04:40 PM
how much will getting it painted to match cost? Also can i take the locking mechanism out and putt it in the new one to have the same key?
Old Oct 7, 2007 | 05:02 PM
hmmwv15's Avatar
yes, remove the little brass (colored) clip, and pop out the tumblers! That easy!
Old Oct 7, 2007 | 05:06 PM
anyone know how much to get it painted?
Old Oct 8, 2007 | 03:13 AM
old4runner's Avatar
if you feel patient you can probably find a toyota being parted out or in the junk yard of the same color.
Old Oct 8, 2007 | 03:39 AM
or rhino line it, it'll probably look cool. Or go to autozone or something and find paint that is close, probably like $4 a can + around 10 for primer and sandpaper...
Old Oct 8, 2007 | 11:11 AM
n4ynu1010's Avatar
Gas Cap Broken
Just get the new one/used one and depending on the color of your vehicle paint it a solid color , have done this before instead of the paint matching thing and it looks nice , other than that you may be able to get the small pressurized can of touch up paint from the dealer by VIN # and re-paint yourself but beware the old paint won't match that nice fresh original paint color , thats why I generally just paint a solid color according to the color of the vehicle and looks nice , otherwise get a used one or new one and have the paint shop do the matching on your existing paint and paint for you but I think you will find that will be rather pricey unless you have a bud that is in the business .
Old Jan 15, 2012 | 04:15 PM
gubni's Avatar
I know this is an old thread but for anyone else searching you can replace the hinge. Lube up the broken pieces with a good penetrating oil. Then use vice grips until they move freely. Then use a small punch to drive out the pin from one end. Then pry it away from the hinge a little and drive it the other way. This allows you to reuse the same fuel door which is important if you paint has faded any.
westonian18
May 1, 2020 06:38 AM
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
Cplmike
Jul 8, 2015 08:47 PM
