gas door
gas door
hey yall,
pulled up to the pump the last night, pulled the gas door pop and heard something hit the ground. sure enough i walked around the other side and my gas door was sitting there on the ground. how can i get the door back on there WITHOUT welding.
thanks for any input
how much will getting it painted to match cost? Also can i take the locking mechanism out and putt it in the new one to have the same key?
Gas Cap Broken
Just get the new one/used one and depending on the color of your vehicle paint it a solid color , have done this before instead of the paint matching thing and it looks nice , other than that you may be able to get the small pressurized can of touch up paint from the dealer by VIN # and re-paint yourself but beware the old paint won't match that nice fresh original paint color
, thats why I generally just paint a solid color according to the color of the vehicle and looks nice , otherwise get a used one or new one and have the paint shop do the matching on your existing paint and paint for you but I think you will find that will be rather pricey unless you have a bud that is in the business
I know this is an old thread but for anyone else searching you can replace the hinge. Lube up the broken pieces with a good penetrating oil. Then use vice grips until they move freely. Then use a small punch to drive out the pin from one end. Then pry it away from the hinge a little and drive it the other way. This allows you to reuse the same fuel door which is important if you paint has faded any.
theking11863
Mar 19, 2016 09:36 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
