anybody know where to get heater core hard lines?
NLA from the Dealer, aftermarket retailer/wholesalers seem to have nothing.
One of mine is has a split in it, the other is kinda buggered up at the rubber hose connection. I think a PO probably overtightened the clamp. Anyway before I can put my dash back together and drive the damn truck again, I need to find some new (hopefully) or good used hard lines. Anybody got any ideas?
I called a few dismantlers today, no dice yet. Anybody parting a truck out that could help me? I do not have rear heat, so its the same as a pickup I guess.
Kevin
87 4runner
Kevin
87 4runner
Heater Core Hard Line
Sounds like a Stealer (aka Dealer) item , if all else fails use some soft refrigeration copper tubing and double clamp it , Stealer probably has it , have to order maybe , good used set sure would be cheaper I bet but you never know ..........Ck the price at the Stealer ............could be reasonably priced
Not available from the Dealer
My runner dosn't have rear heat, so I was talking about the hard lines that run from the heater core through the firewall, the lines you connect the rubber heater hose to...
The dealer can no longer get them. Parts guy at the dealer called Toyota, no dice...
sorry don't have a picture here at work
But they are very much a seperate part. There is an O-ring that seals the connection between each line and the heater core. The dealers blow-up diagram of the system shows the lines even, but they don't have the parts available anymore.
Its looking like used it the best I can do. Anyone parting a low mile truck?
Actually, he's right. I do seem to remember that you could unbolt the water lines from the heater core. I haven't looked at one in nearly 2 years.
I am currently parting out an 88. I can pull the heater core tomorrow afternoon and take a look at it. It may have what you're looking for.
how was that '88?
All the heaters in the junkyards I looked at over the weekend were super rusty. Still looking for good heater hard lines..
May have to fab something, but that would require reworking the heater core outlets a little bit.. yuck, this job sucks the worst
See if you can get a part number and check some other dealers, sometimes a new (or lazy) parts guy will be wrong.
The yota heater core is a monster to replace. You have to pull most of the dash to get it out including the evaporator core which requires that the A/C be recharged when you're done. The dash is literally build around the core.
How about $15 shipped?
** Let me check to make sure that's the one. They both look alike.
The good one is on the right side of the picture.
Thats the one! A good picture for those that were curious how this thing works. Those lines are clamped to the housing, and slide inside the heater core with an o-ring. This is why you must start at the rear bumper to get the heater core out! (My dad's joke when he came by and saw my truck apart....gessh, you gotta start at the bumper?)
I am getting a education myself here
Don't come with the core, The only way you could ever get them is with the whole assembly, housing, core, lines, o-rings clamps etc... everything in the picture used to be sold together as a unit. This is No Longer Available from Toyota. I had two different dealers check into it, one tried pretty hard. No dice. The heater core is still sold seperate and comes bare, by itself.
.I guess you will be replacing those o-rings with some urathane/neoprene ones , I guess rubber would be good but I like Hi Perf. o-rings hehe
