any rock slider pics
Old Sep 29, 2007 | 03:23 PM
weakyota91's Avatar
I almost bought a set of rock slider from trail-gear today for 135 a pair. I am just a little confused as to how there gonna look when there on my truck. I have seen sliders that almost look like a step they stick out so far from the side of the truck I am looking for a set that are very tight to the rockers. Is that just all in how long you cut the legs that weld to the frame and where at on the tube u weld them to determine the positin the sit agianst your rocker panels. If anyone could post pics of your sliders and let me know what brand that would be greatly appreciated thanks.
If the pics shows that is how im wanting them to look.
Old Sep 29, 2007 | 03:24 PM
terryjmatthew's Avatar
You are correct in your assumption. You can cut them to length.
Old Sep 29, 2007 | 03:44 PM
frodin1's Avatar
Here you go, http://www.4runners.org/writeups/stubbs/
Old Sep 29, 2007 | 03:45 PM
OSU4Runner's Avatar
The trail gear set is great because you can cut the legs to whatever length you desire. Did you purchase the mounting kit from them too? I have the same set, and I love them. I'll take some pics tommorrow. I didnt cut the leg at all, so the back edge of the slider rail is even with the rocker. I also put them at a 10 degree cant. Pretty solid setup
Old Sep 29, 2007 | 04:17 PM
weakyota91's Avatar
i havent purchased them yet but will definetly buy the gusset kit it will make it so much easier and the will also be bolt on so they can be removed if needed
Old Sep 29, 2007 | 05:04 PM
BigWavePaul's Avatar
Exclamation tried search?
Narrowing search on Rock Sliders
Pirate FAQ's
Rock Sliderz from 4Crawler
Mine, 4Xinnovations DOM-pricey install, be careful, get an estimate and only trust a true crawler or friend
Old Sep 29, 2007 | 05:32 PM
OSU4Runner's Avatar
I would really recommend welding them to the frame. Its alot stronger then bolting them on. They are still removable with a sawzall and a grinder. You won't have a dozen holes in your frame either. Just my .02
Old Sep 29, 2007 | 05:53 PM
waskillywabbit's Avatar
We have sliders...lots of sliders...as you ARE using a pic of my slider adapter.
http://www.wabfab.org/products/sliders/sliders.htm
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
user 82300
Sep 2, 2015 08:31 PM
94ofCanada
Aug 14, 2015 06:37 AM
priest16
15
Aug 6, 2015 07:43 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
