Brake calibers
Old Oct 2, 2007 | 05:46 PM
kpaxfaq's Avatar
Brake calibers
First off first time on brakes. I heard a grinding noise on the front right disk brakes so i decided to dive in. Turns out on pad was completely worn and the other was like new. Upon closer inspection i cant get the pistons on the engine side to budge at all and they look stuck. i took the caliber off and cant get them to move at all. The others go in fine. Any ideas to fix this? Like i said i know nothing about brakes im just decent at figuring stuff out
Old Oct 2, 2007 | 05:51 PM
DeathCougar's Avatar
Its called a caliper, but the easiest way to fix it is replace the caliper with a new/used one.
Old Oct 2, 2007 | 06:00 PM
waskillywabbit's Avatar
We have the big IFS V6 calipers.
www.wabfab.org/products/brakes/brakes.htm
Old Oct 2, 2007 | 06:08 PM
GSGALLANT's Avatar
You can also rebuild them with new seals and boots from the dealership.
Old Oct 2, 2007 | 06:24 PM
kpaxfaq's Avatar
thanks for the suggestions, how do you get the disc off? I'm trying to replace those too and ive been pounding at everything and i cant figure it out,
Old Oct 2, 2007 | 06:47 PM
89macrunner's Avatar
if you have alreadly taken the caliper off than getting the rotor of is a matter of strength.
BFH works well.
lying on the ground and kicking works also
Old Oct 2, 2007 | 07:58 PM
BFH works well.
uh no.
The rotors are BOLTED to the hubs. YOu can beat on them all you want, and all it will do is destroy the rotors, and possibly even the hubs.
They did not start un-captured rotors until the 3rd gen 4Runners, and Tacomas when they redesigned the front suspension.
Old Oct 2, 2007 | 08:06 PM
FredTJ's Avatar
BFH works well.
Ah yes, another mis-information post on the forum that isn't suppose to hand forth mis-information
As already mentioned, the 2 Gen 4Runners DO NOT have unit bearings.
The rotors are bolted to the hub, which in turn is bolted to the end of the axle shaft.
Fred
Old Oct 2, 2007 | 08:25 PM
Bolted to the end of the spindle, not the axle shaft. lol. BUt i knew what you meant. The axle shaft is held into the spindle with a 12mm bolt, and a snap ring, and the spindle is secured to the knuckle with bolts (forget how many and size right this second)
Old Oct 2, 2007 | 08:32 PM
FredTJ's Avatar
Yup, I'm half asleep, time for bed
Spindle, axle, when he get's in that far he'll hopefully have instructions on what to do, especially setting the bearing preload correctly
Fred
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
