3.0 overheating...help
Old Oct 4, 2007 | 09:45 PM
nix4x4's Avatar
So, in case you're not from where I'm from, Southern Ohio is having an EXTREMELY hot summer/autumn. It was 92 degrees today and humid. Anyway, I've discovered something, my 3.0 HATES hot muggy weather. I was sitting at a long red light today and happened to look at my cluster, and actually watched my temp gauge raise up to just before the red. I freaked, blasted the heat and revved the engine a bit to get the coolant flowing some. It took about 45 seconds to a minute once the light turned green for the temp to get back down into the normal range. What is the problem here? I was just sitting there, no A/C, no crazy driving conditions or anything. At night time when it cooler the problem goes away. Any help? Thanks
Old Oct 4, 2007 | 09:48 PM
ozziesironmanoffroad's Avatar
id replace coolant, hoses, and thermostat.
Old Oct 4, 2007 | 09:50 PM
nix4x4's Avatar
I just put in a new radiator about 3 months ago, so the coolant and hoses are fine. As far as the thermostat goes, as far as i know its factory.
Old Oct 4, 2007 | 09:51 PM
try replacing it. that might help. also check your waterpump... doubt thats the issue, but you never know.
Old Oct 4, 2007 | 10:07 PM
corvey's Avatar
Happens all the time in the same condition? Fan clutch.
Old Oct 4, 2007 | 10:17 PM
fan clutch also. might want to check the flux capacitor also, you know they produce a LOT of heat, since they gotta do all that nuclear work
Old Oct 4, 2007 | 10:51 PM
nix4x4's Avatar
cool whats the part number for a flux capacitor again??
Old Oct 4, 2007 | 10:56 PM
uh... DEL19852201521885 i believe
Old Oct 4, 2007 | 11:04 PM
corvey's Avatar
DEL19852201521886 if you want the polished stainless steel verision...
Old Oct 4, 2007 | 11:07 PM
true, good point corv
Old Oct 5, 2007 | 04:35 AM
chimmike's Avatar
outside temp shouldn't matter, there's definitely something up.
Make sure all air bubbles are out of the system.
I moved recently here in FL, filled the runner with stuff and towed a 5k lb trailer full of crap probably 6-7 times in dead FL heat/humidity.
Old Oct 5, 2007 | 05:11 PM
n4ynu1010's Avatar
Overheating
I had the same problem and it was 2 things that caused it for me :
Thermostat was sticking open and not letting coolant stay in Rad. long enough (like running w/o stat) .
And ,
The Radiator Cap was bad , it has a little one way poppet type valve in middle that allows the coolant to be returned to radiator when coolant/motor cools , it wasn't working so when it got hot coolant left and never came back which eventually led to the radiator being about a gallon low and the motor would get hot as well unless you revved it up a bit .
I had also already replaced radiator and coolant prior to this problem as well .
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
