Can i only re-gear the rear?
I have a stock gearing on my yota and runing 33 yokahamas. and was wondering if i can get away with regearing the rear end only?i am on a tight tight tight budget. cant accelertae on the highway in 5th gear. cant even get up to 75 mph on flat. and really gets old up hills.
thanks guys
thanks guys
if you have to untill you get enough money. Just be caregful not to put the truck in 4x4. I did this last summer. If like you said are on a tigt budget and can only afford on axle right now. Go for it.
you can do it with no problems at all, other than no more 4x4. i would recommend that you remove your front drive shaft so that if you or someone else accidentally puts it in 4wd, nothing bad will happen as long as you dont try to use your 4wd again, at least untill you have the money to regear the front too. and rember if you can take out the 3rd yourself it will save you money, and its not that hard to do.
alright. thanks for the info. i got the truck with brand new 33's on it so i really had no choice. but i guess i will jsut wait till i pay off my debt to get my gears and i dont get my lesence back untill december anyway. thanks everyone!!
Lot's of people do the back first then go back and do the front when they have the cash. You'll be fine if you don't engage the 4wd.
Don't forget that everyone on this website is filthy rich and buys only the finest, most expensive components, and builds their entire truck in a weekend...
I did the same thing but i had 529's in the rear and 488's in the front. me and my friend were messing around in some sand and i got stuck. i ran like 200 feet in 4wheel drive till i got out and it dident hurt anything but i would recomend taking out your driveline.
So if you go over 32", your truck will be a hog??? I did't know that! I'm looking at tires now too. I was thinking of 32x11s as well.
I have a stock gearing on my yota and runing 33 yokahamas. and was wondering if i can get away with regearing the rear end only?i am on a tight tight tight budget. cant accelertae on the highway in 5th gear. cant even get up to 75 miles per hour on flat. and really gets old up hills.
thanks guys
thanks guys
Regear both ends at the same time. Do a rear locker while you're in there.
its not undrive able by any means. i got afriend that runs super swamper 38's with stock gearing on a v6 and thats worse than mine. lol.
From: I live in Red Bluff ca. Right by the Sacramento river
I have 3.90 gearing in the rear of my 81 yota, and put in an axle from an 80, if im correct the ratio in 80 is 4.10, My truck has no prblems in 4x4, jumps a little if it is on pavement, or if it has to much grab. But other than that its fine. Been like that for about a year. I was told that as long as the ratios are within .3 of each other then it is fine. Sand rails sometimes do this, to get the front wheels to travel faster than the back wheels, as long as its not in a bind I think it would be fine.
