power steering question
Old Oct 10, 2007 | 05:23 AM
89red4x4yota's Avatar
ok so another question...if i put the truck in gear and i have my foot on the brake and try and turn the wheel i hear all sorts of sqeeks and there are a ton of hard spots in the steering...power steering pump? new belt? what could it be. thanks guy
Old Oct 10, 2007 | 05:57 AM
INFINITY's Avatar
squeaks could be bushings or tie rod ends (unlubed) or ball joints. hard spots could be low fluid or bad fluid.
i would change the fluid and maybe even put some lucus PS fix in there.
Old Oct 10, 2007 | 06:22 AM
i mean the squeaks are coming form the belt sounds like...any write ups on how to change the fluid? i am also getting a hum from the power steering
Old Oct 10, 2007 | 11:46 AM
anyone?
Old Oct 10, 2007 | 06:32 PM
n4ynu1010's Avatar
Sounds like you may need to tighten the PS Belt and or relace it , slipping belt would cause squeaks from belt and hard spots as the belt is slipping and pump not turning .
ATF Dexron 2 or better should be in PS Pump , flush - disconnect return line (low pressure) hose and either turn it into a pan or do what I do and just leave return line disconnected with pan under it and put a short line to pan on Gearbox Return nipple , fill your pump just before return line inlet on pump and start her up and move the wheel a bit back and forth , watch you pump oil / ATF so you don't run it dry and flush until you get a good color on the oil coming out of gearbox and then re-connect , re-fill and done , the reason I live the return line dis-connected at gearbox yet still connected at pump is so I can purposely fill pump housing over the level of the return line and flush the old oil out of that line as well .
Hum could be low fluid level , old bad fluid or even wrong fluid , supposed to be ATF -Dexron 2 equivilent or better , tighten or replace that belt first though .
Old Oct 10, 2007 | 07:14 PM
thanks n4ynu1010
Old Oct 10, 2007 | 07:27 PM
naadomail's Avatar
Easy way to "refresh" but not flush PS fluid is to drain the pump with a turkey baster and refill with new fluid a few times (3 for me). I did this and noticed better Pwer steering performance.
glowz825
Jan 25, 2022 09:28 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
keithporter83
Jul 24, 2015 07:37 AM
jon.r
Jul 11, 2015 03:34 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
