PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Best Cruising Speed?
  2. 88runner a code 42??????
  3. Aftermarket door mirrors and tail light lenses
  4. Question about 5 digit # near washer fluid resevoir
  5. My first 22RE adventure - lots of questions, advice needed!
  6. Gen1 4Runner pulls left on braking after all re-done
  7. Rear Shocks wanted, 2WD Std '94 PU
  8. no fuel when trying to start hot
  9. 22r exhaust popping upon engine braking
  10. Intake manifold gasket continuing to leak
  11. Minimum amount of emissions equipment to pass a smog test?
  12. Rag joint or steering coupler rebuild?
  13. 94 22RE only runs with VAF / AFM held open manually
  14. Difference in bump start and battery start
  15. 94 V6 clutch / flywheel replacement
  16. Does my 86 22rte need a new head?
  17. I need help with my throttle position sensor for my 1990 3vze .
  18. 86 toyota stick shift.Need Help
  19. 95 pickup fuel issue
  20. Bogging when braking
  21. Looking for 90-94 Toyota pickup
  22. AC pulley
  23. jumping out of second and 4th
  24. Sealant for fuel tank inspection cover?
  25. What Drum to Disc conversion is this?
  26. Ifs box dead spot.
  27. 22re top end rebuild failure
  28. '87 22R Lean Spot
  29. Parts for IFS automatic front hubs?
  30. 87 4runner Ignition switch problems?
  31. 1994 sr5 3.slo fuel tank wiring ...
  32. Why Is It So Difficult To Figure Out A RF1A T-Case Mount?
  33. Grating sound coming from mid/rear of vehicle, corresponds to gas pedal
  34. Brake line(s) to rear on 89
  35. 2nd Gen Alternate Seat Idea - Subaru Seats
  36. 94 4Runner rough idle
  37. 92 Toyota 4X4 Pickup Collision Repair
  38. Replaced valve stem seals without removing cylinder head
  39. Timing Jumped?
  40. Whining through speakers
  41. 4Runner: where is the secret place that the fluids go?
  42. 88 toyota pickup
  43. 94 4runner overheat up hills
  44. 195/75 R14 vs. 205/75 R14 on 92 Pickup?
  45. Rough Idle & Hesitation
  46. Coolant leak drip behind engine, freeze plug?
  47. Stuck in Flagstaff - Back up light wires blowing GUAGE fuse
  48. difficult tire to get off
  49. Starter going bad. Which one to buy?
  50. 22re timing cover gaskets using rtv
  51. 15 x 10s on a 2nd gen pickup
  52. Stock Exhaust replacment: 22re 4wd xtra cab question
  53. New Motor For My '92 Pickup
  54. Fuel issues
  55. What is this black box?
  56. Wiper transmission swap
  57. Fuel pump running but no fuel?
  58. 94 4r electrical burn smell, engine shuts off, wont start
  59. 4cyl v6 Front differential swap
  60. 3VZE Timing belt mystery
  61. 87 4runner won't stay running
  62. 1992 pickup 3.0 missfire? smoke? cylinder1?
  63. 91 toyota pickup front left brakes sticking
  64. 22RE burnt exhaust valve?
  65. Quick Question
  66. what to do about A/C not working?
  67. 89 3.0 EFI Diagram
  68. bracket help
  69. Coolant system pressure test
  70. 1994 SR5 4x4 New brake light switch now lights go out when pedal is pressed
  71. Crankshaft Harmonic Balancer will not go inside the crankshaft issues
  72. What are these tubes?
  73. 3-VZE Fixing
  74. Need advice on new exhaust system
  75. Best way to clean up engine wire harness?
  76. What is best to clean Engine Oil Pump Pickup Tube and screen. OIL PICK - UP. STRAINER
  77. 88 4Runner power help
  78. 87 Toyota pickup high idle low voltage
  79. 88 p/u, trying to swap fuel pump by lifting bed, one bed nut just spins?
  80. transmissioon woes r150f
  81. How to test fuel pressure on a 3.0 vz-e truck
  82. 22R overheating after new head
  83. Does anyone have this suspention issue?
  84. 22re starting sound? Won’t start
  85. 1st gen 4Runner ARB Bumper Install
  86. Most Recommended Rebuild Manual 22RE
  87. Head replacing issue 22re
  88. 3vze Freeze Plug Replacement
  89. Body to frame mount bushings.
  90. Torque Values for Fill and Drain Plugs
  91. Ac install
  92. 87 Toyota pickup starter-relay-wire situation
  93. Front fender removal
  94. 94 Truck - Original Owner Rebuild, advice welcome
  95. Causes of a Rough Warm Idle?
  96. Options and Budget for swaps?
  97. Looking for new cluster
  98. Ebay Engine Question
  99. Need help with 92 toyota v6
  100. Transmission & T-Case Questions
  101. 3VZE TOTAL Timing Advance
  102. 92 3vze pickup misfiring on 1 and 3
  103. '88 22re headgasket(s) nightmare Help
  104. ARB fender side rails
  105. Grinding noise when trying start.
  106. What Is This?
  107. Transmission Woes
  108. Swaping half my frame.
  109. Cable driven speedometer issues
  110. Idle surge
  111. Column shift stuck in park - help
  112. Hi Pinion Diff Interesting question
  113. 22re refuses to reach operating temp
  114. Sr5 Gaige Cluster Swap Question
  115. Coolant temp sensor testing needs to be done at all different temps?
  116. 89 3.0 No Power until 3,000 RPM
  117. Need HELP!
  118. Left rear wheel spins out. Differential problems? 87 4x4
  119. Cracked radiator
  120. Help my radio stopped working
  121. Changing timing belt. 89 3.0. Help.
  122. 89' manual carb pickup high idle
  123. Loud noise when turning please help
  124. best paint for red on Aisin hubs?
  125. 94 3.0 3VZE engine wiring harness / connectors
  126. 22re power steering swap; worth it?
  127. Bad Idle Air Control Valve?
  128. 4Runner slows or jerks when letting off the gas
  129. 93 rear window 'dead'
  130. Crush washers are made from ...
  131. Dash button?
  132. 1987 4Runner Paint Pitted w/ Rust.
  133. no power brakes and hissing from the brake pedal?
  134. '88 V6 ext cab Toyota 5spd - Help!
  135. Check Engine Light and Code 71
  136. 1990 22re will not restart when it reaches operating temp
  137. 87 Centrelink Stabalizer Bolt Rubbing on Pinion Stop
  138. Diagnosing starter problems
  139. 89 V6 needs a new front end
  140. 1993 2wd pickup engine swap
  141. egr air temp delete
  142. 86 4runner 22re (w56) EFI Relay Voltage Question
  143. Starting a warm/hot flooded engine
  144. Snap-on mt2500
  145. Transmission Bolts to Engine
  146. ARB locker leaks air
  147. Trail Gear gm alt bracket broke, alt belt snapped, alt making noise now
  148. leaky rear window seal
  149. best ball joint for 2nd gen 4runner
  150. Replacing the exhaust on '88 4Runner 22re
  151. 93 Pickup 3VZE died, wouldn't start, ran again
  152. 95 4Runner Wheel size?
  153. Sos
  154. Identify this wire
  155. Driveshaft Quick Disconnect Experiences?
  156. CV Boot Question
  157. Need help identifying the function of these VSV's
  158. Vibration In Driveline after OME CS009R installe
  159. Starter Relay Re-Wire or Retrofit for 95 and earlier Trucks / 4Runner
  160. What brake line fittings are on our 4-Runner and trucks?
  161. 95' Pickup 4x4 5spd 22re Stuttering Issue
  162. Ongoing Single-Click Starting Problem
  163. 1989 toyota pickup pull hard right when braking
  164. Temp sensor gauge or sender?
  165. Rear third member identification
  166. Slipping in reverse. Adjustments?
  167. Just did the starter relay mod -wow!
  168. Speedo cable making noise
  169. GM 4l65E transmission to Toyota transfercase
  170. opinions please......
  171. coolant in passenger floor pan
  172. Why my Engine Temp. Fluctuates.
  173. '93 3vze AT new rebuild and is Lazy dog.
  174. blown head gasket?
  175. 1989 Pickup 22RE
  176. Need Help Won't Start
  177. weather deflector clips
  178. Lucas transmission leak fix for power steering pump?
  179. Timing chain guard
  180. 5VZ-FE swapping a '94 4runner for my goddaughter
  181. 22RE Rough Idle/Stalling Issue
  182. 86 Toyota auto T-case
  183. 93 Toyota pickup front end question
  184. 91 vs 92 3VZE Knock Sensor
  185. Is 14mpg bad?
  186. Oil cooler
  187. intermittent brake pedal pulse
  188. Turn Signal Parking Light Mod
  189. Balljoint spacer install question
  190. 1" Brake Master Cyclinder
  191. 3vze crank timing pulley
  192. hose snafu
  193. ACC buzzer
  194. 22R Weird Carb Issue
  195. Windshield replacement and trim 2nd gen 1995
  196. Water in floorboards
  197. ADD bypass
  198. Fan won't turn off
  199. Do I really need ecm on 22r ;86?
  200. '92 22RE Strange Intake Noise
  201. im back....check engine codes 13 and 22
  202. ECU question
  203. Rear panel reinforcement
  204. Cutting out around 4grand under load
  205. Stuck Pilot Bearing
  206. 95 4runner 3vze melted 80a fuse - need help/advice
  207. ALTERNATOR (22RE) mistery problem (?)
  208. dash mat pictures/did i get the wrong thing?
  209. clutch master cylinder differences
  210. Where to Find Decent Replacement Quarter Panels
  211. Where are you guys buying replacement snap rings for w56b transmissions
  212. "Accelerator" cable to transmission. If broke what happens?
  213. 22re
  214. Replacement RWD parking brake cables?
  215. Quick, Temporary Fix for Fuel Line Leak
  216. Jeep Bumper?
  217. T4R first gen - Rear wheel drags
  218. Mysterious extra hose coming out of the air intake hose, 3vze?
  219. What does the 4wd wire on the ECU do?
  220. Need Ideas For Fuel Pressure Tester
  221. 3.4 swap passenger side not firing
  222. Parasitic current draw - 1986 4runner
  223. Sanity Check about broken 4x4
  224. Can't check timing, please help
  225. 86 4Runner - Rear Window Relay Issues/ Questions - 85930-89101 165000-0452
  226. 91xtra cab 2.4 / 2wd /man
  227. Front wheel hub / flange: washers stuck in all 6 studs. How to without breaking ?
  228. Need a wiring harness
  229. Locking Hub Nut
  230. Engine rebuild kit for 3vze
  231. CV axle, Are they the same Driver/Passenger?
  232. 92-94 4Runner Bumper removal & Spare tire Hanger
  233. 3vze - WHY does the coolant go through the throttle body please ?
  234. Rear axle seal replacement question
  235. Torsion bars on a 1994 extended cab 4wd pickup
  236. Compatible Vehicles
  237. Trouble Understanding Diagnostic Codes: 1989 4runner 3VZE
  238. Need to replace knock sensor. What else should I do while I'm in there?
  239. Fuel tank drain plug size
  240. IFS front wheel stud replacement procedure (?)
  241. 93 Toyota Pickup timing
  242. back again 94 yota 22re engine help
  243. Replacement Fuel Injectors
  244. Question about spring length and weight for no-cut Zuk mod.
  245. Rear End Vibes
  246. 22re replacement
  247. Factory Sound Deadening
  248. Running start up hills
  249. 22r and 22re production numbers?
  250. Transmission Swap Question
