transmissioon woes r150f
Old May 10, 2019 | 05:00 PM
Robert Mason's Avatar
I pulled trans to replace my input shaft bearing due to noise. Had a shop do the actual pressing of the replacement bearing. after i reinstalled the tranny seamed like all was going well able to go forward and back. heres where the troubles start i pull into my driveway has a decent incline and try to go back to reverse as long as i put gas into reverse works fine it wont rollback while clutch pedal is down.
I re pulled transmission and tried to spin the output shaft by hand in each gear in all gears except reverse i can spin the shaft easily by hand. Then i tried to put in neutral to spin both input and out put shafts if looking at the bell housing straight on it spins normally going clockwise feels like it starts to bind going counter clockwise.
i have tried a few things removing the input bearing plate the gearbox spins fine as soon as i tighten it back it seams to bind again.
Old May 10, 2019 | 05:20 PM
superex87's Avatar
Sounds like the new bearing was not pressed on all the way or is the wrong bearing.
Old May 10, 2019 | 05:25 PM
no longer have the old one to compare it is pressed to the snap ring i will try to post a pic in a few min
Old May 10, 2019 | 05:37 PM
bearing agenst snap ring
bearing number
Old May 10, 2019 | 06:50 PM
have been tearing tranny apart more have found that the 5th gear thrust washer was broken at keyway. and its looking like 3rd gears synco is binding on the taper
JeEVeS
Apr 12, 2009 06:31 PM
1tonMike
Jul 3, 2008 02:30 PM
GTE4runner
Feb 27, 2006 07:52 PM
Jackpot2
10
Jul 5, 2004 08:57 PM
riverrat
Nov 30, 2003 04:53 PM
