93 Toyota Pickup timing
Old Mar 25, 2019 | 03:54 AM
Jooosshua's Avatar
I am looking to find out what the timing is supposed to be set at on these 22re motors. I have read where it should be at 5 degrees before tdc. And whoever set mine set it right at tdc.
Old Mar 25, 2019 | 04:05 AM
ev13wt's Avatar
5 Year Member
It's 5 degrees with the connector jumped.
- about 12 without the jumper.
https://www.yotatech.com/forums/f116...r-wire-212353/
Does your idle go down slightly when you set the jumper? If yes, set your timing to 5°.
If no, check TPS adjustment first: https://www.4crawler.com/4x4/CheapTr...PS/index.shtml
Old Mar 25, 2019 | 04:08 AM
Jooosshua's Avatar
Yes my idle does go down with the jumper. Thanks for the help! I will fix it as soon as I get back to the house
Adrianchiino
May 16, 2013 07:34 PM
4x4doog
Nov 4, 2012 12:06 PM
lokirx7
Jan 29, 2011 09:48 PM
4X4Yota4X4
All Other Toyota Swaps
Jan 23, 2010 08:16 PM
WFR112373
Jul 8, 2009 06:30 PM
