93 Toyota Pickup timing
I am looking to find out what the timing is supposed to be set at on these 22re motors. I have read where it should be at 5 degrees before tdc. And whoever set mine set it right at tdc. |
It's 5 degrees with the connector jumped.
- about 12 without the jumper. https://www.yotatech.com/forums/f116...r-wire-212353/ Does your idle go down slightly when you set the jumper? If yes, set your timing to 5°. If no, check TPS adjustment first: https://www.4crawler.com/4x4/CheapTr...PS/index.shtml |
Yes my idle does go down with the jumper. Thanks for the help! I will fix it as soon as I get back to the house |
