Factory Sound Deadening
Old Mar 23, 2019 | 05:47 AM
mrgtstr's Avatar
I have a 1995 xtra cab and currently tackling the interior. The factory deadening material is fairly thick in areas and undecided on whether to remove it completely and put all new down or add additional in the needed areas or go over top of all of it. My only concern about going over top of it, is when putting the carpet back of it being too thick. I am leaning on removing all of it and then putting down deadener and sound insulation from here.
https://www.amazon.com/stores/node/12073767011?_encoding=UTF8&field-lbr_brands_browse-bin=Noico%20Solutions&ref_=bl_dp_s_web_12073767011 https://www.amazon.com/stores/node/12073767011?_encoding=UTF8&field-lbr_brands_browse-bin=Noico%20Solutions&ref_=bl_dp_s_web_12073767011
Any thoughts would be appreciated.
Old Mar 23, 2019 | 11:39 AM
ksti's Avatar
My suggestion would be to purchase something that also takes heat in to factor.
I did not see anything about any heat rating in the link you posted.
Just my 2 cents worth.
Old Mar 23, 2019 | 08:31 PM
RAD4Runner's Avatar
Originally Posted by mrgtstr
...The factory deadening material is fairly thick in areas and undecided on whether to remove it completely and put all new down ...
IF the factory sound deadener is intact, why go through the trouble of removing what those excellent Toyota engineers chose to dampen vibrations with?
deadener and sound insulation.
These are the keys. ^^^
Deadener to minimize vibration of the panels, AND insulation to prevent whatever remaining vibration/sound and heat from above the exhaust and the firewall from coming through.
I put a 3/8-inch rubber pad above my sound-deadened floor, PLUS thermal/sound insulation on firewall and the floor area above the exhaust, yet the carpet still fit well. Just make cut-out as precisely as possible where pedals would travel to, and where seats and seatbelts would mount.
Old Mar 24, 2019 | 12:07 PM
mrgtstr's Avatar
Thanks for the feedback....I am considering the 80mil for the deadening and the 170mil for the thermal barrier unless I am misinterpreting the product description.
Old Mar 24, 2019 | 12:14 PM
mrgtstr's Avatar
True....Thought process is a clean slate so to speak.
What kind of thermal insulation did you end up using?
That being said....I would think If I put what i am wanting down on top of whats there I should be okay on the carpet then.
Old Mar 24, 2019 | 05:20 PM
RAD4Runner's Avatar
Thickness is no issue. In fact, before putting carpet back, I built-up dips on the floor with extra padding I had.
I posted what I did and used here:
https://www.yotatech.com/forums/f116...r-work-259455/
Truck body sounds very good now, except for the loud 22RE. I wish I has put sound-thermal insulation on engine side of firewall when Inhad engine rebuilt.
I might be able to but it would be tight to work in.
You can also apply some on cabin side of firewall to some extent.
Brad
Dec 9, 2004 09:23 PM
bradym239
18
Nov 25, 2004 12:01 AM
gwhayduke
11
Aug 22, 2003 07:09 PM
