Rear panel reinforcement
Old Apr 2, 2019 | 07:21 PM
rsmdon's Avatar
Has anyone come up with a good way to reinforce the rear panel in 1st gen 4runners where the doors cover the jack and tool kit?
Old Apr 3, 2019 | 04:42 AM
keycw's Avatar
5 Year Member
yep. make your own.
Old Apr 3, 2019 | 07:33 AM
ev13wt's Avatar
5 Year Member
Out of wood.
Else, you could simple tape sticks of flat plasic everywhere behind it, to make it more ridgid. Then some felt where it contacts the body. Install!
Make sure you use "high temp capable" double sided tape if you don't want a gooey mess.
Old Apr 3, 2019 | 07:34 AM
keycw's Avatar
5 Year Member
I suppose its possible to simply layer some fiberglass onto your oem ones. maybe someone with the toyotafiberglass panels came chime in and say if they are sturdy enough for you. any particular reason?
Old Apr 3, 2019 | 11:23 AM
rsmdon's Avatar
Thanks guys, I found some fairly decent ones in a salvage yard and just looking for a way to keep them that way.
Old Apr 3, 2019 | 11:32 AM
keycw's Avatar
5 Year Member
post up if you come up with something clever. they are pretty flimsy.
Old Apr 4, 2019 | 01:14 PM
881stgen's Avatar
I read on another forum that some guy did the fiberglass reinforcement, which I will probably do with mine too since they are in good condition. Just lay fiberglass on the back and it will be much more rigid.
Old Apr 4, 2019 | 01:43 PM
RAD4Runner's Avatar
MEH, Those stock doors are too tiny. I modified mine to use entire body cavity for storage.
https://www.yotatech.com/forums/f116...71&gid=1&pid=1
Thread also has Toyota Fiberglas' (Slacker) post on his product: Replacement Inner quarter panel.
Old Apr 4, 2019 | 07:26 PM
rsmdon's Avatar
The fiberglass reinforcement sounds promising. I will have to do some research on how to do something like that. Rad4runner, I had seen your thread on your panels and storage space. Nice work!
Old Apr 5, 2019 | 01:25 PM
881stgen's Avatar
I also like the idea of making custom panels for more storage, but I've always wanted to keep everything as stock looking as possible.
Old Apr 5, 2019 | 03:39 PM
rsmdon's Avatar
I like the stock look also.
AW1090
11
Oct 3, 2011 06:05 PM
VaTech4wd
Jul 28, 2009 08:30 AM
KZN185W
Jun 16, 2007 03:38 PM
mudbone
Dec 29, 2002 09:28 PM
