Stuck Pilot Bearing
Old Apr 2, 2019 | 03:53 PM
J-Yota918's Avatar
Stuck Pilot Bearing
I have a 1987 toyota pickup single cab 4x4 5 speed 22r pickup with a rusted out bed. Not all needed but just throwing that out there. I have a stuck pilot bearing. I dropped the transmission because 5th gear destroyed itself and I'm in the process of doing some other maintenance while it's out. I tried an Autozone pilot bearing puller. Broke the puller. I read about filling the cavity with grease then using an extension to hammer in and press the bearing out. The extension got stuck. Now the extension is well greased and well stuck. I'm trying to find guaranteed solutions and I'm pretty much tired of trying stuff that doesn't work. Any ideas are appreciated.
Old Apr 2, 2019 | 05:10 PM
Paul22RE's Avatar
5 Year Member
Did you try to put vice grips on that extension and try to bang it out and at least get the extension out? The grease method did work on my 92. On my 87 4Runner many, many years ago I think I ended up using a small grinding wheel to cut the bearing sleeve.
Old Apr 2, 2019 | 07:06 PM
Lons81's Avatar
If you can remove the extension, you might try packing the center of the bearing with white bread. Using a punch to really get in packed in from behind it should to push out the bearing. Continue filling until bearing comes out. Clean out the cavity and install new bearing. Worked on my 81, even though it sounds weird
Old Apr 3, 2019 | 04:44 AM
keycw's Avatar
5 Year Member
I couldn't get the grease method to work. I just did this job last month. I used small strips of paper towel soaked in water, stuff them into the cavity, then used a bolt the same size as the hole and tap it with a hammer. keep stuffing paper into it and tapping with hammer until it pops out. ive used this trick on three Toyotas.
Old Apr 3, 2019 | 05:02 AM
coryc85's Avatar
I've used both the bread method and the wet paper method (wet paper, wet paper towels) and they both work well. I've never used the grease method because it seems too messy to me.
Old Apr 3, 2019 | 05:36 AM
snippits's Avatar
I would try what Paul said to get the extension out.
Also, slide hammers can be outfitted with vise grips. There are adapters available that attach a vice grip to a slide hammer.
This guy on Youtube used a Harbor Freight slider hammer, and attached one of their vice grips to it. All you have to do is remove the adjusting bolt for the pliers, and then screw the threaded shaft of the slide hammer into the pliers.
Old Apr 3, 2019 | 08:01 AM
arlindsay1992's Avatar
I tried the grease method, it was messy and squirted everywhere. It didn't work for me. Next I used the bread trick. That worked awesome. I've done it three times. It's important to use an extension, bar, or bolt that slides nicely into the bearing but isn't tight and doesn't have much play. Too small and it won't seal up, too big and it'll just get stuck.
Old Apr 3, 2019 | 11:15 AM
jazz1's Avatar
5 Year Member
Heat it up, will slide off or at least break the bond that holds it. Never had a pilot bearing give me any issues amazingly.
Old Apr 3, 2019 | 04:49 PM
J-Yota918's Avatar
Okay so I got my inner race and the balls out. Now my outer bearing is stuck. I'm not sure how to get it out. I've tried a dremel and put notches in it bit it's still pretty well stuck in there. I've been using a 1.5 inch dremel EZ lock steel cut off wheel. I had bought 15/16 but the center hole grinds itself before the metal. I'm very much stuck. I'm appreciative of all help I've recieved and hope to get a little more.
Old Apr 3, 2019 | 05:10 PM
Paul22RE's Avatar
5 Year Member
Only way at this point is to slice/weaken that outer sleeve and then pry it out.
Old Apr 3, 2019 | 05:23 PM
87-4runner's Avatar
Take a diamond point chisel and dig it into the rim of the bearing and drive it like your trying to unscrew it... either direction works wherever your able to get the most swing on a good sized hammer...
Old Apr 5, 2019 | 11:39 AM
ev13wt's Avatar
5 Year Member
Remove cage. Remove inner race with force.
Buy pilot bearing puller. Not the slide hammer version.
Use it.
Old Apr 7, 2019 | 03:23 PM
J-Yota918's Avatar
I appreciate all the help everyone. I ended up getting the outter race out with a slide hammer and bigger pilot bearing tool. Popped off in two seconds after a 3 day battle. I put in the new pilot bearing and now I'm waiting on a gasket to come in. New rear main seal is in as well. I'm inching towards having the truck back as my daily driver.
Old Apr 7, 2019 | 04:36 PM
bearcat2's Avatar
I never had any luck with the grease method, it does lube everything up nicely so you can't get a grip on anything, though. I made a slide hammer with a hooked end out of some steel rod I had laying around and a ten pound sledge head, that got it out. Of course the only one I've ever had a problem with I had the motor out of the truck and on the shop floor so I had lots of room to work. Would have been much more of a pain under the truck using my fabricated slide hammer, but I made it with about 18 inches of slide and a ten pound hammer, it really put some force to it.
Old Apr 8, 2019 | 07:31 PM
J-Yota918's Avatar
Here is the new pilot bearing in and it turns well. The black piece looks to be a little bent from installation somehow but it rotates without noise friction so seems to be good. Glad to have put to rest the biggest issue in the smallest part I'm changing.
Old Apr 8, 2019 | 11:01 PM
ev13wt's Avatar
5 Year Member
How did you fubar the seal?
Always drive in bearings with the outside race!
Old Apr 10, 2019 | 06:28 PM
anndel's Avatar
Glad you got it out and new one in, great job! BTW I used this on my pilot bearing/clutch project: OTC 7318 Pilot Bearing Puller
https://www.otctools.com/products/pi...aring-puller-3
jsrusse11
Feb 3, 2010 04:51 AM
Tubbyfatty
Jul 3, 2009 12:32 PM
allnmstkn313
Jul 14, 2008 07:06 AM
bamayote
Jan 21, 2004 09:25 AM
