Transmission Woes
Old May 4, 2019 | 12:28 PM
Zomalaja's Avatar
Transmission Woes
1994 4Runner 2WD V6(3VZE) Auto. when cold, at 60 MPH, engine speed is just over 3000 RPM. Once it's warmed it is just over 2000 RPM at 60 MPH. Ideas greatly appreciated. Fresh fluid, filter changed a few days ago. Old fluid not dirty or burnt smelling.
Old May 4, 2019 | 06:55 PM
Co_94_PU's Avatar
You are aware the transmission doesn't shift into overdrive until the system is up to operating temperature?
Old May 4, 2019 | 07:38 PM
millball's Avatar
Sounds like it's working as designed.
Old May 4, 2019 | 09:10 PM
Zomalaja's Avatar
I am not touching the overdrive button at all. I have had the car since it was new and I'd guess I have only pressed that O/D button 5 times - The behavior has changed. Are you saying that when cold, that overdrive is off but the dash light doesn't indicate that it is off ? My dash light either says "O/D Off" or nothing.
Old May 5, 2019 | 09:56 AM
scope103's Avatar
... Are you saying that when cold, that overdrive is off but the dash light doesn't indicate that it is off ? My dash light either says "O/D Off" or nothing.
Correct.
The O/D switch is just to "force" O/D Off. Otherwise, Overdrive is under the command of the computer. Which means: no Overdrive when cold.
JulsTirn
17
Jul 19, 2008 02:50 PM
gray420
Jan 17, 2007 08:56 PM
Dublin
Oct 1, 2006 03:10 PM
Urban4x4
9
Feb 11, 2006 10:48 AM
schooner
Dec 2, 2003 03:13 AM
