PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 1987 Pick up light problems
  2. 86 4runner slow crank
  3. Transfer case: ATF or Gear oil? Also a transmission capacity question.
  4. Misfire at idle, many parts replaced
  5. 87 4runner power loss at 2k RPM, poor acceleration
  6. Stock rear spring replacement for 93 pickup 4x4
  7. remanufactured 22re wont start, turns over but wont fire.
  8. Need source for 1987 Carburated fuel pump- lines rusted
  9. 1989 Toyota pickup with the 3vz won't hold an idle
  10. timing belt
  11. Automatic tranfer case with a manual trans?
  12. Campatable tranny's for 88?
  13. 2kW starter question
  14. 87 22rtec needs help to run
  15. 1988 pickup wont keep a charge
  16. 1993 4x4 truck V6 Questions
  17. Help with locking (or not) hubs
  18. Gauge mounting help
  19. Rod Knock Donor engine
  20. 1994 4Runner stuttering/hesitating on acceleration
  21. Gotta 911 in Jacksonville FL for mechanic
  22. G52 to W56 transmission for diesel.
  23. 95 SR5 3vze head questions
  24. Complete failure from worn pressure plate fingers?
  25. weird timing issue
  26. Best Thermostat for 3VZE
  27. Always in overdrive - A340H auto transmission
  28. Adding oil cooler to '88 V6
  29. Aftermarket Japanese Water Pumps
  30. Idle issue
  31. New rebuild won't start.
  32. Can someone post a pic of 1st gen rear wiper?
  33. 93 22re 4x4 build up
  34. Where does this connect to?
  35. What would you do?
  36. Rear brakes locking
  37. 94 Pickup Rolls Away
  38. a/c works intermittently and for a variable amount of time
  39. 90-95 Toyota 4Runner FSM
  40. 87 22re Pickup - only runs with Fp B+ jumped
  41. 88 Xtra Cab 22re M/T Crank No Start
  42. '92 pickup running hot, no obvious reason why
  43. 1986 Toyota 4wd Pickup
  44. 95 4runner 3vze hesitation and stumble after warmup
  45. What connectors is for the injectors?
  46. 3vze Plenum Removal Issue
  47. 86' Runner Coolant Leak from this Fitting
  48. 93 3.0 3VZE Fuel Rail
  49. Stripped bolt holes
  50. Radiator cold unless revving it up
  51. grind noise in 4WD
  52. Help: O2 sensor resistance reading
  53. pickup shakes when first start up
  54. Steering wheel 90° to right HELP
  55. 22RE No Start Condition.
  56. 89 4Runner, 5Sp - Console and other interior parts
  57. Could someone help me identify what goes in these slots?
  58. 22r vacuum leak at egr? help! vid included
  59. 1993 sr5 4x4 truck egr valve wires
  60. stalling issue on 95 4runner v6
  61. Leaf spring question 94 xtracb 4X< 89 oneton 2wd
  62. Help: brake light blinking on Dash
  63. Man Trans Oil
  64. Headlight Upgrade with wiring Schematic
  65. Headgasket question
  66. Washed my engine big mistake
  67. Bodylift
  68. Transfercase
  69. Transmission swap work list, still trying to find where two bolts go
  70. Intermittent, random knocking
  71. Wiring Harness Questions
  72. Fuel issue. Need help ASAP!
  73. 86 4Runner pre-purchase questions?
  74. First Gen. 4runner Turbo, Auto Tranny, Crackin' Flex Plates
  75. Confounding information on 5 speed swaps in my pickup.
  76. New to me 89 4Runner
  77. Is this on backwards? Trans input shaft seal
  78. 2 extra bolts after tranny swape
  79. Weird electrical issue with the dashlights coming on and off and car not starting?
  80. Bench seat
  81. alternator upgrades
  82. eBay headers
  83. ECM resistance values dont make sense
  84. EFI Still A Mystery to me (and my cousin)
  85. 2nd Gen 4Runner Radiator Manual Trans
  86. Distributor Position ? 3VZE
  87. 93 2wd 5spd 22re ran out of gas and now it doesn't start
  88. 93 2wd 5spd 22re ran out of gas
  89. 3.ol v6 Auto to 22RE Manual SWAP
  90. Tailgate window switch - grounding the switch
  91. 3.0 Bent rod?
  92. '93 4runner low compression excessive oil burn
  93. Vsv identification
  94. 94 4runner 3vz heater problem
  95. I think my tach is finally fixed!
  96. 95 4Runner mystery noise, speed related
  97. Clutch issue? Transmission issue? Both?
  98. No Start 92 4R V6 AT 4x4 (<95k)
  99. Fuel Rail Fuel Pressure
  100. Having hard time wiring flatbed LED lights
  101. Anyone happen to have the dimensions for rear coil upper isolators?
  102. 89 22R Idle and Fuel Cut Sol. Idle Issues
  103. Trail gear rear bumper
  104. Fuel Delivery Problem (Please HELP) 94 pickup
  105. 92 3VZE Smog Fails - High NOx, then High NOx & HC
  106. Parking brake cable - difference between 4cyl and V6?
  107. 1st Gen: Passenger Seat Mod - Extend The Seat Track
  108. 89 pickup to flatbed conversion
  109. Bolts and Studs for Rebuilt 22RE
  110. Special Grill for 1986 2wd xtra cab long box?
  111. Alternator Bolt (nut) lost
  112. Flamethrower Injector Issues?! HELP!!!
  113. Stuck front wheels, like really stuck
  114. Dome Light swap
  115. STC (Kayline) Soft Top Questions
  116. Toyota rookie...need some info
  117. Not another rear window thread - Well, kinda
  118. 86 4Runner Rear Driver side lean
  119. 95 Toyota Pickup 22re, Left For a Week, Now She Won't Start
  120. RPMs Too high for gearing. Thoughts?
  121. Over heating after replacing radiator??
  122. Ignition timing jumped 17 degrees
  123. !987 4runner
  124. 93 4Runner engine knowledge
  125. Bad OBD Port?
  126. Distributor cap contacts chewed up
  127. Another verification of knuckle/CV axle seals question
  128. 22re efi choking?
  129. Shackles for leaf springs
  130. Manuel transmission help
  131. T4R 88 first gen rear bumper cap end
  132. Cannot find what's causing misfire!!
  133. 91 toyota 4x4 pick up wire problems
  134. Help with emissions
  135. 91 4x4 pick up Fuel to spark problem
  136. Identify my gearing
  137. Air fuel issue (I think)
  138. 2 4runner builds (pats thread)
  139. Slide oil pan out when doing clutch?
  140. 80A main
  141. Failing brake booster? Idle erratic w/pedal down, but not when vac hose plugged.
  142. Selectable lockers available?
  143. blown motor?
  144. Blown Motor?
  145. 22REC how much vacuum is normal at idle?
  146. 22re Clattering with no load
  147. 3VZE Low power, I give up
  148. 22RE rebuild or replace/3.6 swap
  149. Tailgate inside plastic lock broken
  150. 95 4Runner 3.0 Newbie Seeking Direction
  151. just got bad news. Cam bearing?
  152. Idler pulley bearings
  153. Mimic injecter pulse? ??
  154. Special Seats? 86 Bench seat that says "Toyota 4x4"
  155. 2 Door 4Runner Flares
  156. HOONING in the back yard..... 18" of snow
  157. Ack! my new to me 3rd gen has a wet and rusty rear axle, should I start shopping?
  158. Toyota Engine Builders Springfield
  159. 22RE rebuilt cost vs rebuilding cost.. this truck has me pissed
  160. 1990 3VZE with no spark from coil
  161. Anyone have a V6 4.88 w/ a Truetrac for sale?
  162. Can anyone identify these Distributors?
  163. CV axle rattling in front hub
  164. Highbeams won't work
  165. Piston size and marking question
  166. milliamp draw electrical question
  167. Grinding from Clutch Housing
  168. LCA capture washers
  169. Transmission failed on 86 4w4. Swap G54 for W56?
  170. Running lights and tail lights come on when trucks off and no key in????
  171. 1990 4runner AC trouble
  172. 94 4Runner idle and thermostat problem
  173. 1989 Pickup Blower Issue
  174. What a way to be back
  175. Cracked firewall
  176. Unable to set timing, 3vze v6 89pu. Timing jumper not working?
  177. can i use forklift parts.
  178. Will this effect alignment?
  179. '89 Pickup 22r Problem with VSV
  180. 2nd Gen 4runner rust replacment panels.
  181. What's causes this?
  182. windshield cowl panel
  183. Auto Tranny Leak
  184. Rear Main Oil Leak
  185. Air cleaner mods
  186. Aftermarket mufflers - Any quiet suggestions?
  187. 3vze Bogging after driving
  188. Speedometer cable issue w/ video
  189. 94 4Runner 3.0 Low compression on #4
  190. 2nd gen 4runner won't start after stuck parking brake
  191. 22RE bad crank = not happy!
  192. 93 2wd springs
  193. Wanting to find a gift for my Boyfriend that is 4runner related
  194. My last try before the dreaded mechanic visit
  195. Transmission Rebuild kit
  196. 87 4runner roof info-tailgate lock bolt
  197. initial start and idle then backfire
  198. I just bought a 87 Toyota pickup,short bed, with a Weber carb 22R,need help with!
  199. Mystery rubber nipple on throttle linkage?
  200. finishing up a head gasket job and I have no idea where this bracket belongs
  201. 95 Runner 3.0 code 14 and 52
  202. Help me identify this missing sensor please
  203. 94 22re start/idle problems
  204. Trouble after rear brake rebuild, need help
  205. 93 22re cranks and shuts off cranks and shuts off won't rev over 2000 rpms
  206. Considering Fresh Paint... Is Xtra Cab window weatherstrip available anywhere?
  207. Loud ticking and bogging after tune up
  208. Add a leaf
  209. What am I working with? Lift?
  210. 88 4runner lift kit question.
  211. Oil looks milky and smells like gasoline
  212. 94 pickup 4wd won't engage
  213. Proper 3vze VAFM Readings
  214. Rear axle movement + jamming brakes
  215. 1993 22re 4x4 issue
  216. Transmission won't remove from engine
  217. Why is my cam gear off?
  218. Help with tranny leak
  219. 22re replacement help!
  220. HELP with PAIR valve problems
  221. Need help
  222. Toyota pickup 4x4 94
  223. Another Emissions Thread
  224. 22re tap the gas to start
  225. 1st Gen 4runner Rear Flap Window
  226. Wet rusty fluid under boots on wheel cylinder
  227. Chain issue? Egh
  228. 91 timing tensioner
  229. 86 vs 87 grille
  230. No ALT light, engine on and off.
  231. Exhaust manifold swap
  232. 90 pickup 3.0 cruise control issue.
  233. Lurch/jerk/vibrations
  234. 22re Runs Terrible
  235. 3VZE truck extreme pinging & stumbling
  236. Replace guage cluster / Speedometer
  237. advice for my 3VZE 89 4RUNNER AUTO
  238. sliding window and seal
  239. 89 Pickup Fuel Tank/Sending Unit/Pump Hanger Leak
  240. 1987 Toyota 4Runner Turbo- Re-doing fuel system, tank, pump, lines, etc.
  241. no kick down in transmission
  242. AFM question
  243. Oxygen Sensor
  244. 87 front breaks do over
  245. Is this axle wrap?
  246. 22R flicking noise then cuts out
  247. Okay to take off the A/C belt?
  248. Right Way to Get These Shifter Boots Off?
  249. clutch or tc?? need help
  250. R452 5th Gear in R150/R151
