Transmission won't remove from engine
Old Feb 28, 2017 | 01:27 PM
Diego toyota's Avatar
Greetings one an all. I've been trying to remove transmission from engine while In Toyota, I Couldn't.
I then removed engine an transmission, they will not part. Any ideas? Can someone help thanks . 90 Toyota 22re.
Old Feb 28, 2017 | 04:17 PM
dropzone's Avatar
Fossilized
sure you got all the flex plate bolts etc off and all 4 main bolts, the starter is off etc ...
I have had to attach a small come-a-long to pull a tight trans off
Old Feb 28, 2017 | 04:46 PM
Everything is off, their is an inch of opening I can see the teeth an pressure plate between tranny an engine.if I pry between both i get in an half clearance but it won't separate.
Old Feb 28, 2017 | 11:48 PM
wyoming9's Avatar
Red face
What transmission Manual or auto ??
Auto the torque converter needs unbolted
If a manual spray with the penetrating oil of your choice they do tend to get hung up on the pins
Now that it is out of the vehicle it will be harder .
Get a helper so you can both pry at once rather then just one side and getting it twisted putting on more pressure
Old Mar 1, 2017 | 02:02 AM
it's a manual, thanks
Old Mar 5, 2017 | 02:26 PM
ShadowTek's Avatar
Reminds me of when I was dropping the 5-spd on my '88. It just wouldn't separate more than a fraction of an inch, so I kept pulling and yanking and wiggling. Then I realized that I'd put the nut back of the stud for the starter so I wouldn't lose it, and forgot it was there. I'd been pulling against that dust cover the whole time. lol
Old Mar 6, 2017 | 05:19 AM
I ended up going to a transmission shop, to attempt to separate the engine from the transmission. I was told it would have been much easier had I kept it in the truck because they both wouldn't be moving at the same time while pulling one from the other. Get to find out it was the push out bearing being stuck.Due to lack of grease or it sitting for such a long time. It took lots of prying with the longest an biggest pry bar I've ever seen. But it happened. Thanks for the response.
