no kick down in transmission
Old Feb 21, 2017 | 12:39 PM
rhinodad700's Avatar
i have a a 1994 toyota 4 runner 255000 miles on it had transmission issues before mostly shift solenoids
the other day the check engine light came on (tps sensor) no 5 volt signal at reference wire it was bad so i replaced it
now the transmission has no kick down does it have any thing to do with the tps sensor
when testing the tps signal i noticed there was one wire with 12 volts on it what is that for??
Old Feb 21, 2017 | 12:46 PM
scope103's Avatar
A few periods, or commas, in that sentence might help.
Your transmission is electronically controlled, and the TPS is an important input. If the TPS is not working correctly, it probably won't shift correctly.
Do you know how to test the TPS? http://web.archive.org/web/201108151...93throttle.pdf
Old Feb 21, 2017 | 01:03 PM
Co_94_PU's Avatar
I think you have mixed up your notes. TPS has four wires, none of which should have 12 volts. VAFM has five wires one of which is battery voltage.
If you really have 12 volts on Vcc at either you've shorted a few wires together or your ECU is faulty.
Old Feb 21, 2017 | 01:09 PM
tps only has 4 wires. and one does have 12 volts on it. and i didn't short out any of the wires
could one of the injector wires be shorting to one of the tps wires giving me 12 volts??
they do run throuhg the same loom.
Old Feb 21, 2017 | 01:19 PM
Co_94_PU's Avatar
Pop open the kick panel, unbolt the ECU, locate the VCC wire and UN pin it from the plug. Now turn the ignition to run and test the voltage output from the ECU on VCC. If it's not 5volts it's an ECU problem, if it is 5 volts it's a pinched wire..
There are a lot of wires it could be and they all run thru the shared engine harness..
Old Feb 21, 2017 | 01:31 PM
do you have a diagram to tell me what wire is the vvc wire
Old Feb 21, 2017 | 01:53 PM
Co_94_PU's Avatar
Nope! Because you didn't give the full vehicle spec
Old Feb 21, 2017 | 02:00 PM
Co_94_PU's Avatar
Middle plug. top right, or third from the right bottom row, when viewed with the plug releases at the top.
Old Feb 21, 2017 | 02:05 PM
Co_94_PU's Avatar
Ps
You don't have a kickdown cable, it shifts when it wants to...
Old Feb 21, 2017 | 02:09 PM
thanks for the help
Old Feb 21, 2017 | 02:11 PM
some input must tell it when to down shift im assuming tps has a lot to do with it
