2jz-GTE in a 1986 Pickup
Hey gang!
I've got a good lead on a 2JZ-GTE and I want to throw it in a 2wd pickup. Can anyone point me in the right direction as far as accomplishing this?
Thanks yall!
-Jackson
Thanks yall!
-Jackson
Probably my electrical skills are the weakest. My budget is not large :/
Are there any existing threads of people doing this?
1 Post
www.supracharged.com
You will need the engine and tranny at minumim. Depending on your power goals you may also need to change the rear end. Plan on a full fuel system and cooling system swap.
1 Post
The stock tank will be fine. You'll just have to get a high flow pump and since you're there anyways I would run new fuel lines too since they'll have to end up in a different spot in the engine bay.
