2jz-GTE in a 1986 Pickup
Old Feb 17, 2017 | 12:46 PM
sweitzerworks's Avatar
Hey gang!
I've got a good lead on a 2JZ-GTE and I want to throw it in a 2wd pickup. Can anyone point me in the right direction as far as accomplishing this?
Thanks yall!
-Jackson
Old Feb 18, 2017 | 12:01 AM
wyoming9's Avatar
Red face
Do your research!!
Where are your skills the weakest ??
Anything can be done with a large enough budget !!
If possible bring the complete engine donor vehicle home .
If not make sure the engine harness and ECM is all there
Old Feb 18, 2017 | 09:06 AM
Originally Posted by wyoming9
Do your research!!
Probably my electrical skills are the weakest. My budget is not large :/
Are there any existing threads of people doing this?
Old Feb 18, 2017 | 03:11 PM
space-junk's Avatar
yes. theres a search bar up at the top that will be your best friend through this endeavor.
Old Feb 19, 2017 | 06:44 AM
nothingbetter's Avatar
www.supracharged.com
You will need the engine and tranny at minumim. Depending on your power goals you may also need to change the rear end. Plan on a full fuel system and cooling system swap.
Old Feb 19, 2017 | 10:03 AM
Thanks for info man. Stock tank won't do?
Old Feb 19, 2017 | 10:33 AM
The stock tank will be fine. You'll just have to get a high flow pump and since you're there anyways I would run new fuel lines too since they'll have to end up in a different spot in the engine bay.
Old Feb 19, 2017 | 10:40 AM
Understood, thanks.
