Toyota pickup 4x4 94
Old 02-27-2017, 09:57 AM
Jen N Ray Dix's Avatar
When in 2wd drives fine lock in 4wd makes vicious clicking sound have changed inner and outer tie rods the manual locking hubs and idler arm still doing it any ideas
Old 02-27-2017, 12:17 PM
wyoming9's Avatar
Red face
Best thing to do is get it up on jack stands lock the hubs and move things till you find what is loose.
I would look at the CV axles and Front drive shaft
Old 02-27-2017, 01:06 PM
Fossilized
Staff
dropzone's Avatar
I deleted your other thread on the same subject, please don't create multiple threads on the same subject
Old 02-28-2017, 10:46 PM
RSR
RSR's Avatar
Oil in your front diff? Fluid in transfer case?
If both of those, then my guess would be CV axles over front driveshaft, as driveshaft should be more a chirping if just U joint going bad provided you haven't completely broken a U Joint -- if broken then U joint will click.
