PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 [147] 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Need quick advice
  2. front diff problem
  3. 22re clutch/rear main questions
  4. please help i put k&n on and blow efi fuse every time i try to start truck
  5. U Joints for dummies!
  6. Smokecoming from valve cover
  7. gear swap
  8. 95 4runner back to the original look
  9. Rebuild FIRST start!
  10. Where does the RET turbo tap for oil?
  11. 1st gen 4runner. Gears and mpg
  12. Starting issues after sitting -Hilux Surf
  13. strange drive shaft noise
  14. power antenna masts the same between generations?
  15. Can anybody Identify this Transmission?
  16. offroading Syracuse/Longisland area
  17. My truck just died fuel problems any Ideas
  18. power steering pump adjustment bolt
  19. Engnbldr T chain kit
  20. 3VZE Leak Help
  21. Advice for an aged truck
  22. Your Experience with Speedy/Redi Sleeves?
  23. Wait, I thought I bought a Toyota?
  24. vacuum leak
  25. Need help with a bolt
  26. 93 4runner, cranks no start
  27. CB Radio Install
  28. enough clearance to replace rear wheel stud without pulling axle from backing plate?
  29. just got a job at chrysler, might have to sell the yota :~(
  30. CCA needed for a 22re?
  31. bad mpg
  32. 1988 22RE Pickup - refresh
  33. Weber Carb. Help
  34. recalls
  35. fuse ?
  36. New injectors or rebuild old ones? 22re
  37. Speedo disassembly Question
  38. 86 turbo 5speed. 4x4 not working.
  39. 87 22r Crank Bolt seized!! What now? Removal Help.
  40. new toyota truck
  41. best plug cap rotor & wire combo for 22re
  42. Steering wheel wobble.....Help?!
  43. 3.0 Check Engine hooray.
  44. 87 4runner cab?
  45. Rough Idling,
  46. 4WD locking hub anomaly
  47. 91 22re stalling around 1500 rpm
  48. map light bulb removal
  49. horrible gas mileage why???
  50. Front main crank seal
  51. PA Owners: who has swapped their cab? what you do w/ VIN #'s ?
  52. the lift...
  53. still having fuel issue
  54. killed the Red Top, oil pressure is gone, alt isn't charging anything.
  55. 90 4Runner - 3ZV
  56. TPS low idle, EGR removal
  57. Putting Brake Lines Back In
  58. for i have killed a toyota
  59. Clogged breather = blown axle seal
  60. camshaft replacement question
  61. Starter clicks a few times then starts?
  62. Glove box handle broke off.
  63. Emergency Brake light Flashing
  64. 90 22re engine problems after washing
  65. No compression after head gasket replacement?
  66. 1989 22re Exaust Valve squeak? help
  67. california emissions
  68. Wiper Arms?
  69. Fusible Link Wire
  70. the start of my front bumper (Pics)
  71. Clutch Problem? 1990 7M-GTE Longbed 4x4
  72. I LOVE SOLID AXLE 3RD GENS!!!! pic thread
  73. Question about Rancho shocks
  74. electrical short /speedometer ???
  75. Big problem, dont know what it is?
  76. Got stuck, fed up with lightweight bed (pics)
  77. 3vze top-end rebuild?
  78. Starting issues
  79. 22RE rebuild for the first timer.... where to begin??
  80. 1988 Toyota Truck Won't Pass CA Smog
  81. Lessons learned timing chain, cover, guides, etc.
  82. 22R Questions.
  83. Dim Headlight Issue
  84. At 2k RPM it sounds like its gonna blow up.
  85. Another 3.0 or a 3.4
  86. Another head gasket question
  87. 1995 3.0 No start/Flooding
  88. 22R - Odd Issue
  89. Differential Slip and noise?
  90. Front cover bolts!!!!
  91. 02 sensor Test 94 3RZ
  92. proper exaust diameter
  93. Transmisiion wont go in gear?
  94. Pulling Alternator...Question
  95. Might buy a '89 4x4 ex cab v6 truck. Few ?'s
  96. who's running a turbo encabulator in their 4Runner?
  97. is this a tranny cooler?
  98. Pic of stock 22ret anyone?
  99. location of diag. port?
  100. favorite seat covers
  101. This can't be right can it? P/O Converted ADD to Manual Hubs
  102. LCE Adj Cam Gear
  103. high compression pistons in 22re
  104. made it back safely!!
  105. lifting the rear to level it out
  106. A304H Temp Gauge an Filter Change
  107. Leaking radiator?
  108. thread lock on the idle adjustment screw?
  109. troubleshooting 4X4 - not engaging
  110. Drum Removal Help.
  111. horrible gas mileage after rebuild
  112. help with surging idle 22re
  113. 89 Yota 22re
  114. flex pics!
  115. Brighter brake/tail lights on my '88 pickup?
  116. 22re head with shim???
  117. Odd electrical issue...
  118. A few of these a double dog dare and a trip to Wal Mart
  119. Wheel Seal Problem
  120. 225/75/15 VS 31x10.50r15
  121. axle housing destroyed???
  122. 92 3vze best engine swap???
  123. comealong as winch?
  124. ECU Compatibility '87 4runner?
  125. What clutch???
  126. Locker
  127. Fuel mileage qestions...
  128. Idle Screw On TB Rotates Over Time
  129. Transmission Help!!!!!!
  130. 93 4runner sooo lost...
  131. 22R - update
  132. 1991 toyota 3.0 4x4 engine problems...
  133. Best Magnaflow prices?
  134. can you put a 95 tranny in a 94?
  135. Failed emissions
  136. Lifting 1988 4Runner
  137. bed-liner'd the back
  138. B&G Fiberglass
  139. Is my CV Gone???
  140. I'm back in the game...
  141. The '86 is worm food........
  142. Need an auto electrician in the Tacoma area...
  143. *HELP with Gearing* 4.30:
  144. New 2nd Gen 4Runner
  145. Why do some rear differentials have sensors, and others dont? Please see pics inside
  146. ADD front axle shafts
  147. some sort of cover for chopped back?
  148. exaust leak, need gasket
  149. My turbo runner
  150. 91 4runner stuck in forward gear
  151. worth the cost?
  152. power steering pump, new or rebuild?
  153. Eletrical issue HELP!!!!
  154. HELP!!! Break down in Seattle
  155. supra afm swap issues
  156. auto to manual hubs
  157. Consistantly decreasing Idle
  158. Odd Question About My truck
  159. Fuse locations, diagrams, etc. (especially Horn)
  160. Removing the Bed on my '88
  161. Gas Mileage
  162. newbie question about front shocks
  163. Eng Fuse Blows instantly...
  164. 94 SR5 parts Runner?
  165. CV boot keep breaking
  166. Instrument Panel problems
  167. problems during main bearing replacement - any tips?
  168. Fluid Leak under drivers side dash
  169. dealing with smog...
  170. Timing chain time
  171. Upgraded wiring harness from 4crawler
  172. Sound?
  173. Another Head Gasket Repair and solutions
  174. obx headers?
  175. 4runner hitch on a pickup?
  176. slow starting
  177. Fuel Pump Removal
  178. Strange Starting Issue
  179. Newbie with a tranny question
  180. New Toy in Washington
  181. Just got my first 4Runner
  182. Re-Re Painting The Truck
  183. fuel line question
  184. air compressor or welder?
  185. 22re #3 miss
  186. 22re Knock sensor wire problem has me stumped
  187. Kijiji Ad That Might Interest Ontarians
  188. Downside to Arizona vehicles??
  189. speed sensor /gas mileage
  190. Fuel Pump oil leak?
  191. Pre ignition/Pinging
  192. DIYPNP on a 22RE, Anyone?
  193. removing front hub, i'm stuck
  194. 95 auto 3.0 4runner tune up guide help
  195. Engine Light... what does it mean
  196. Where to buy A/C idler pulley
  197. Sputtering.. Backfiring
  198. ? about what will happen to front diff
  199. 3VZ engine change, but not the "rest of the story", yet
  200. already fixed starter, what next?
  201. ADD shifting
  202. 4X4 not working. troubleshooting??
  203. Removing EGR/Emission 4Y
  204. 94 4Runner build question (K8MNSTR)
  205. 1991 4Runner Electrical Issue---Please Help!
  206. Whats this wire?
  207. Quick Question: Are all A340H Transmissions the Same?
  208. knock sensor and wiring
  209. Driveshaft vibration
  210. AC rebuild checklist
  211. 22 RE Front engine oil leak
  212. Modified Trd decals!
  213. LEDs in Dome/Cluster/etc.
  214. 94 vs 92 4Runner
  215. White smoke when stopped, blown head gasket what to do?
  216. 2wd 0-60 vid
  217. Toyota Cab/Fender/box swapability.
  218. 22re dead?
  219. Vibration - 4WD shifter knob
  220. Gas Smell
  221. Stock Center Caps 95 4runner
  222. Swapped out my turn signal/headlight/wiper combo unit...got problems now.
  223. TRailmaster IFS Lift Part Number
  224. Pulsating idle on startup?
  225. Spot Lights
  226. Bleeding the clutch
  227. Cold start knock
  228. Vibration
  229. 92 toyota rear Leafs
  230. Coolant temperature switch?..
  231. Tranny prob? I think i am in deep dukey...
  232. First gen 4runner hard top modification
  233. Huge fuel mileage decrease with front hubs locked.
  234. Oil is leaking out of top timing bolt hole cover
  235. Whill older gen fenders fit myy 88' PU looking at 81' style
  236. thinkin of rebuilding the 3.0
  237. 95 4runner Fuel Filter Fun
  238. need help with 93 22re fast idle
  239. a few questions about 3rd gen's.
  240. LC eng mpg
  241. Advice with LC Install
  242. Name This Mount
  243. Strange rear window problem. 87' 4runner.
  244. Heater/Defroster problem... nothing coming out of vents
  245. 22RE-inconsistent idle
  246. engine siezed?
  247. My New Ride
  248. new cat time
  249. egr plate gasket
  250. 22re fuel filter relocation
