Eletrical issue HELP!!!!
Old Oct 29, 2009 | 03:36 PM
dustins's Avatar
Okay, no dash lights, no running lights, turn signals and hazards use to work, now niether do, but headlights and high beams ok. Only thing I can assume is the multi function lever/switch is bad. Anyone agree, or think anything else.
Old Oct 29, 2009 | 04:22 PM
Kiroshu's Avatar
Try to clean your battery terminals.... check fuses...
Old Oct 29, 2009 | 04:55 PM
milehigheric's Avatar
Do you get wipers? Is the battery charged? A wild guess would lead me to the ignition barrel. Head lights do not need an ignition feed, explaining why they are still working. Check the barrel for correct continuity with a multi meter...
Old Oct 29, 2009 | 05:35 PM
dustins's Avatar
Wipers work, battery is fine, headlights dont need an ignition feed but when the headlights are the dash lights should come on with them as well as turning lever to the running light position.
Old Oct 29, 2009 | 07:14 PM
Have you done a continuity test on the indicator/headlight stalk?
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
rjtrials
Aug 6, 2015 07:25 PM
Esibnitsud
Jul 30, 2015 08:19 PM
