Eletrical issue HELP!!!!
Okay, no dash lights, no running lights, turn signals and hazards use to work, now niether do, but headlights and high beams ok. Only thing I can assume is the multi function lever/switch is bad. Anyone agree, or think anything else.
Try to clean your battery terminals.... check fuses...
Do you get wipers? Is the battery charged? A wild guess would lead me to the ignition barrel. Head lights do not need an ignition feed, explaining why they are still working. Check the barrel for correct continuity with a multi meter...
Wipers work, battery is fine, headlights dont need an ignition feed but when the headlights are the dash lights should come on with them as well as turning lever to the running light position.
Have you done a continuity test on the indicator/headlight stalk?
