Fuel Pump Removal
Old Oct 28, 2009 | 10:27 PM
CHEEZBURGER's Avatar
Fuel Pump Removal
I have no Idea which side of this fitting to turn to finish disconnecting my fuel pump, I have searched and came up with nothing, but also I am not good at the search thing, I feel like such a noob but you guys are all I have
I have also PB'd the crud out of it
Old Oct 29, 2009 | 02:44 AM
ayoung101's Avatar
you turn the fuel line side, not the pump side. but good luck, it's probably rusted on and will just rip off, requiring you to replace the line. that was a fun problem i had last year. . .
Old Oct 29, 2009 | 05:44 AM
Smythley's Avatar
Let me know how your fuel pump removal goes, I have to tackle it this weekend.
Old Oct 29, 2009 | 06:01 AM
Tubbyfatty's Avatar
It looks like you have to turn it so the top end goes to the left. The nut looks like it connected to the bottom part of the line.
Old Oct 29, 2009 | 06:36 AM
ayoung101's Avatar
and i can't stress enough how careful to be when doing it. mine snapped right off, and i had a helluva time finding a replacement. later on, i realized i shouldn't have wasted my time finding the correct part and jerry rigged it
Old Oct 29, 2009 | 07:48 AM
Ok, I am just going to jerry rig it, should I cut the metal on the hanger and use some fuel line and clamps or should I cut the hose and put in a metal tube and some clamps?
Or is there a better way you guys can think of?
Old Oct 29, 2009 | 09:26 AM
MuddinRI's Avatar
Don't cut anything unless you can replace it with the right part. pb blast that connection and the wrench it off if it breaks you need a sending unit $175.00 from the dealer. I did mine a few months ago gl.
Old Oct 29, 2009 | 09:51 AM
Smythley's Avatar
So you turn the large nut in the photo?
Old Oct 29, 2009 | 09:54 AM
I've tried both ways, PB'd it last night and this morning and can't get that sucker off of there, I stripped out the small one a little so I am using vise grips on it now and it just wont budge, I'm gonna go try some more but I think I'm gonna be out a bunch of cash
Old Oct 29, 2009 | 09:58 AM
MuddinRI's Avatar
Well If anything try not to harm the fuel line(rubber one) looks like you might need to buy a sending unit anyway you got the tank down and no sense n doing that again.
Try cutting the metal hose on the sending unit so you can get a better angle on the rubber hose to take the piece apart
Old Oct 29, 2009 | 10:24 AM
Tank is still in the truck right now, I broke the metal one so I am now going to try to rig something after I try cleaning up the pump, it's freakin nasty, any ideas how to clean it up, or should I buy a new one?
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
