4WD locking hub anomaly
Old Nov 2, 2009 | 07:54 PM
BlackNite3's Avatar
I've owned my '88 4Runner for a grand total of 1 week and am becoming very familiar with this site. When I bought it, the previous owner told me that the front wheel bearings needed replacement. It made a fairly loud roar on the drive home so I knew it would need to be addressed. Yesterday, I got my hands greasy tearing it apart to replace the bearings. When I pulled off the locking hub, I found that the single bolt that goes in the axle shaft was not attached. It was actually "loose" inside the locking hub's cap. I found that the bolt had been jammed in there in such a way that the head had ground a ring in the cap of the hub. Here's a blurry pick, but I think you get the idea:
I'm wondering if the bolt backed itself out and was riding against the hub. I have a replacement bolt already, so no worries. Should I be worried about the hub itself? I'll be cleaning it thoroughly to keep the metal shavings out of my new bearings.
On a related note, I chuckle everytime I "un-rig" a previous "repair" only to find that the original configuration actually works properly. For example, the rear window was wired into a toggle switch on the dash because it mysteriously stopped working. I put a roof bolt in the hole for the top switch, re-connected the motor wiring, and voila! The window works. Just funny.
Old Nov 2, 2009 | 08:05 PM
waskillywabbit's Avatar
Hub dial will be fine. Just put the bolt/washer back in the end of the axle shaft and snug it up. Typically snug enough to spin the axle is enough.
Old Nov 2, 2009 | 08:09 PM
peow130's Avatar
Are you working on your hubs in the laundry room o.0?
Old Nov 2, 2009 | 08:15 PM
BlackNite3's Avatar
lol... no, that's the tag from my last pair of Mechanic gloves My work bench isn't exactly clean, though
Old Nov 2, 2009 | 08:26 PM
peow130's Avatar
Suuuuure.
Anyways, i agree with the wabbit, the dial is fine lol.
jaretstuff
Aug 4, 2015 02:08 PM
defrag4
Jul 31, 2015 10:50 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
