Fusible Link Wire
Old Nov 1, 2009 | 10:41 PM
flyingbrass's Avatar
Fusible Link Wire
Is the wire that goes from the positive battery terminal to the 80 AMP fuse in the box "fusible link" wire or ordinary wire?
I had to cut mine years ago to replace the terminal. I crimped a new end on, but it's annoyingly short. I'd like to replace the wire, but I'm not sure what to use.
Old Nov 1, 2009 | 11:05 PM
eli-sky's Avatar
fusible link specific, should only be about 2 inches long and something like 10 or 12g wire. run a thicker wire to it , 10g or 8g
cheers
Old Nov 1, 2009 | 11:57 PM
wyoming9's Avatar
Red face
depending what year you have the fusible links are in the fuse block by the battery .
Your lead off the battery could just be 8 gauge wire.
Old Nov 2, 2009 | 12:29 AM
It's a 1986 22R. The wire is long enough (barely now) to reach from the box to a post on top of the battery terminal.
If Toyota hadn't confused matters by calling the fuse a fusible link, this would be a lot easier to figure out.
80Truck
Oct 12, 2025 07:25 PM
sandyota
Feb 4, 2021 11:16 AM
kirkrunner
Jul 27, 2015 07:59 PM
1994toyota
Jul 17, 2015 03:03 AM
