supra afm swap issues
Old Oct 29, 2009 | 03:02 PM
franky's Avatar
I just completed a afm swap using a 1982 supra afm,before tiding up the wiring i tested it and got a no start, it ran for 3-4 seconds then died, if i tried again it wouldnt fire at all,if i waited a couple min and tried again it would start for another 3-4 seconds. did anyone else have problems like this??/
Old Oct 29, 2009 | 04:17 PM
BigBluePile's Avatar
Nope, did you read out all the connections on the Supra AFM?
Old Oct 29, 2009 | 04:28 PM
franky's Avatar
read out? its not starting with the stock afm either now, i didnt touch anything but the afm, must be in the wiring since i relocated the afm had to lenthen wires
Old Oct 29, 2009 | 04:40 PM
Junkers88's Avatar
Yeah you probably need to trace all the wires you modified and check the connections.
Old Oct 31, 2009 | 02:16 PM
franky's Avatar
so i put afm back to stock and used the stock afm,no run, changed the ecm ,no start, checked all fuses,no start,i can head the fuel pump kick in but cant tell if it keeps running after it fires
Old Oct 31, 2009 | 03:02 PM
olharleyman's Avatar
check the efi 15 amp fuse on the right fender?
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Coreyr384
Jul 10, 2015 11:13 AM
