PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 1.75 inch BJ Spacer question
  2. Luke warm Heat
  3. Timing chain issues on 89 4Runner
  4. Transmission troubles
  5. 94 4Runner project
  6. Trouble with brand new 22RE build. HELP!
  7. 91 4runner ran out of gas. no start.
  8. rev limiter on 22r
  9. 93 pickup with grinding noise...
  10. 3vze compression test
  11. 1987 DLX Rear Bumper
  12. 1990 3.0L. Won't start--help!!
  13. 4hi whine and jerk
  14. Engine swap
  15. Transmission interchanges
  16. 22re missing, stumbling when warm
  17. Correct Aisin clutch master cylinder 3vze 4runner 1989
  18. Leaf spring replacement question.
  19. Engine low temp
  20. Can't get rid of code 25 w/ rich emissions, despite research
  21. Best Catalytic Converter For 1993 V6 2Wd
  22. Parking brake cable blues
  23. Alternator Regulator bad?
  24. Ring Job? And Did I Cause it?
  25. 94' 22re Rebuild Questions
  26. Glitter and Grease near Clutch Fork
  27. Oil pan stuff
  28. Best Place for bumpers for a 1991 4Runner
  29. 1990 pickup
  30. Are these brake master cylinders the same? (Aisin vs ...BMT?)
  31. 22r Choke replacement
  32. 95 4run radiator fan on 91 pickup???
  33. 1986 22re fuel issue?
  34. 87 4runner woes...
  35. 1st Gen 4Runner Front Bumper Brackets
  36. 22R Won't Stay Started When Cold
  37. Blower speed and ignition wires questions
  38. Engine Won't Rev above 2krpm and Smokes!
  39. 3VZE won't fire after overhaul
  40. weak brakes, fluid coming out of reservoir
  41. 89 pickup not holding charge
  42. parasitic electrical draw
  43. 95 4Runner has no power on acceleration
  44. Wheel sound not a bearing not a shock mount.
  45. Redneck Engineering question
  46. Rear ends
  47. 2.4L EFI 22R-E in '86 Pickup; Idles rough at low RPM
  48. Stock A/C Conversion: Experts Wanted/Knowledge Needed.
  49. 3VZ-E Oil Pump-to-Block O-ring size
  50. Body lift question
  51. Help identify 3rd member
  52. unable to pull codes
  53. Cold Start Injector Low Voltage (22re)
  54. My timing chain replacement progress.
  55. Re: Replacement for Power Antenna
  56. W56-C Trans pops out of 1st and no 3rd
  57. Help With Upper Idler
  58. I need to know if I messed up on timing removal.
  59. Front Bumper rubber mount part#?
  60. Gas gauge goes wonky
  61. Cooling jackets, head/block
  62. looking to change tire and rims
  63. 1994 toyota pickup
  64. 86 22RE stumbles, lopes, hesitates when revved
  65. Help a newb, tire fitting question about 33's, with photos
  66. 1993 22re. Am I at tdc?
  67. Stock rear shackle length
  68. 1988 Toyota 22re
  69. 1988 Toyota 22re
  70. Missing timing cover bolt ?
  71. '93 3L V6 4runner warm idle surge
  72. Replaced wheel bearings and still getting rough ride.
  73. shock eye to eye 4runner
  74. 88 pickup doors wont open
  75. Headlight wiring messed up?
  76. Are LCE H-Beam Connecting Rods Worth Getting?
  77. Windshield wiper travel limits
  78. 88 Pickup missing diagnostic port.
  79. new tach has got me a little confused
  80. Califonia (CARB) question
  81. diy dent removal
  82. Floating seal and deposits found in radiator.
  83. Engine question
  84. Exhaust manifold thread
  85. 94 3.0 v6 starting issues
  86. 91 4x4 22re harness
  87. 94 Sunvisor Broken
  88. Passenger rear squeal?
  89. hubs for '94 sr5 4wd
  90. shock therapy
  91. 87 4Runner Chrome Rocker Trim
  92. 92 pickup ATF gushing from around torque converter
  93. 1987 22RE sputtering
  94. 22re starts but wont run
  95. newb to the gas world!
  96. Trucks idle is crazy
  97. Parts Diagram
  98. Need help with my 95runner won't crank
  99. Clutch replacement
  100. 88 22RE RWD Power Steering into 93 22RE IFS 4WD?
  101. Bull bar or Grill guard
  102. Another 5VZ swap thread
  103. Coolant for 1st gen
  104. Positive camber with passenger side cam "maxed out"
  105. Newbie question about VSV's
  106. New here with first truck.
  107. Is Electric Power Steering Available for 22r/re powered pickups?
  108. Is LCE Performance any good?
  109. new '94 SR5
  110. 94 pickup 22re
  111. 22re 94 toyota pickup
  112. Replacing the Rear Axle Wheel Bearing and Seals on the Toyota 8” Rear Axle
  113. Leveling kit
  114. 94 toyota pickup 3.0 mpg issues
  115. no power to the cold start injector time switch
  116. 3VZE stumble / cut out at highway speeds.
  117. Deleting heater core ?
  118. Faulty Air Locker Solenoid?
  119. 86 4Y 4Runner - low power, misfires, bad mileage
  120. 3vze warm start issue
  121. Use Chevy overload or not?
  122. 93 Pickup Rough Idle, Rough Low RPM, Low Power, Bad MPG
  123. Frame rust/holes....how bad is it?
  124. 1991 22re to 1987 22ret swap
  125. NEED ADVICE! Buying my 1st Yota 4runner
  126. Reliability of Auto Transmissions?
  127. Doug thorley tri y header air injection gaskets
  128. Replacing Coolant Bypass Hoses
  129. 87 22rte EFI Problems
  130. Are New Bolts Required For 3VZE Head Gasket Replacement?
  131. 88 pickup electrical problems
  132. Ebay Aluminum Radiator - Japan Racing Products
  133. 1994 pickup R150f rebuild kit
  134. 88 sr5 gauge cluster connector pinouts..
  135. 93 pickup lift ideas
  136. 86 pickup 4x4 not engaging
  137. 1988 4 runner brakes
  138. Windshield wipers. Who has this problem?
  139. 88' 4Runner: Air in clutch system
  140. Alternative to AFM - Mazda MAF?
  141. Please help!!
  142. 30 inch curved or staight light bar? 1991 pickup front bumper.
  143. Hood scoop
  144. Transfer Case Rear Output Shaft Seal
  145. help! with 1990 4runner 2d cylinder head gasket
  146. Blown Headgasket Questions
  147. Best oil high mileage
  148. Ignition coil location
  149. 95 sr5 five speed 4x4 clutch issues
  150. Tips and parts
  151. Bump Switch
  152. Sunroof wont seal properly
  153. 4Runner won't shift into second gear unless I let my foot off the gas pedal?
  154. Brake failure
  155. Engnbldr oil pump?
  156. turn signal problems
  157. Code 12 3.0
  158. EGR Delete and CO levels
  159. The engine arrived
  160. 89 toyota transmission help
  161. Charcoal Canister
  162. What should an R150F feel like?
  163. Manual to auto trans swap wiring... Please help
  164. Looking for some clarity
  165. 86 22re crank but no start
  166. Odd hesitation?
  167. Hard to get into gear slave cylinder replaced
  168. Hole underneath fuel pump?
  169. Randomly stuttering engine, backfires
  170. 94 22re idle surge under load.. WITH A STRANGE TWIST!
  171. 94 pickup distributor replacement 22re
  172. Time for new rear axle bearings, some questions
  173. 1989 pickup with 3vze problem HELP
  174. 3vze headgasket advise
  175. 1990 22re will not start
  176. Latest opinions/fixes on dread code 52 = KS
  177. Brand new battery, no electrical power
  178. Spare Tire Fun (New Mount and/or Replacement Winder Crank)
  179. Overheating question
  180. Dimmer switch
  181. Toyota gremlins 3.0 issue.
  182. are there wiring differences between...
  183. rear glass broke on the 4runner
  184. no high beams 88 4runner
  185. Timing Chain – Miles vs. Years
  186. Auto trans
  187. 1993 toyota pickup temperature guage sensor location?
  188. Help timing
  189. Weird problem HELP!
  190. Looking for a water leak
  191. 91 4runner 3vze crazy high idle cold and warm
  192. Window vents with small swivel windows
  193. Is my engine doomed?
  194. 3.4L swap or 350 small block v8 fuel injected swap.
  195. blower fan not working
  196. leaking valve cover advice
  197. Distributor test for 1991 3.0?
  198. Lights on but wont crank
  199. 1994 Sr5 3.0 5 speed
  200. Best engine option 86 pickup 22r, carb?
  201. Help! 93 4Runner 5spd 4x4 3vze need help getting heads back together
  202. 4 wheel drive slips in L1
  203. Violent shaking in rear end
  204. Gear Shift Selector Light Bulbs In Instrument Cluster
  205. '94 Pickup Whine ~3k RPM
  206. Extreme vibration at low speed acceleration
  207. Wiring Up Driving Lights to Switch
  208. acceleration hesitation
  209. 3.0 vaccum lines. Pics needed
  210. Do you adjust valves... Hot or cold?
  211. Vent window
  212. What is the proper operating temp range on a A340H tranny
  213. Tuning and tweaking my 1st gen ´86 4runner
  214. my DD /86 22re , I can figure it out ?
  215. Charcoal Canister ReRouting
  216. 22re working hard 94 4Runner
  217. 1987 4runner cold start issues
  218. Tacoma rear axle for 1st Gen 4runner???
  219. 1987 4runner Auto to Manual Swap
  220. rear diff freeway whine
  221. 1994 R150 synchro
  222. 88 3vze pickup No start. code 14
  223. 22RE to 3.4 swap
  224. Engine rebuilders in the nor cal bay area
  225. 22re making a ticking noise
  226. NEED HELP!! popping out of first gear
  227. Idle high in park, normal in drive.
  228. 87 xtra cab seats
  229. Rear Bumpers Plate Style - Group Buy!!
  230. 1993 Toyota 3.0 RV (gas tank question)
  231. Missfire and disappearing coolant. Good compression test #s
  232. Automatic hubs
  233. Alternator,power steering idle pully on 88 pick Up
  234. Intermittent starting issues. Single click
  235. 87 Runner Starter/Electrical Issue
  236. 89 pickup 3.0 help
  237. Burnt Valve or might I get lucky???
  238. Losing brake fluid in freezing temps
  239. Please help me ID this coolant hose!
  240. Wheel Bearings
  241. Extending Rear Links on a 8" lifted 2nd Gen
  242. Main starter wire change?
  243. Where can i get Window Control Module Relay 85980-89101
  244. Crank, No Start. Need Some Help
  245. 88 vs. 89-95 3VZ-E Left Exhaust Manifold
  246. gauge cluster help?
  247. A340H transfer case bearings
  248. 22RTE Tailpipe Suction, Misfire at idle
  249. 2"Body lift no 2nd or 4th gea
  250. 87 or 85 what should I build
