Help timing
Old Dec 7, 2015 | 01:51 PM
BrownRecluse's Avatar
Help timing
I can't get my timing just right:S using a timing gun set to 5 degrees before tdc I just did my timing chain in 22re not enough power up hills
Old Dec 7, 2015 | 03:54 PM
Terrys87's Avatar
Are a tooth off on your distributor? You may need to pull the distributor and install it again.
A Timing Video I like Better. Set Crankshaft pulley to 5 degrees.
Timing Video
http://www.youtube.com/watch?v=9qEQM...ature=youtu.be
Easy way to install distributor on Youtube.
Old Dec 7, 2015 | 06:50 PM
Obmi's Avatar
When i did mine on my 22re I had to jumper the connector.
http://www.lcengineering.com/LCTechP..._NOTE_AUG.html
yota884huntn2
Apr 17, 2016 04:50 AM
Warren Morris
Nov 25, 2015 03:29 AM
Obmi
Nov 20, 2015 04:55 PM
jhsantacruz63
Nov 12, 2015 08:12 PM
blairbushproject
Nov 12, 2015 04:53 PM
