1988 Toyota 22re
Old Dec 29, 2015 | 06:54 AM
Brad5363's Avatar
1988 Toyota 22re
My 22re is pumping gas into my block and flooding the motor out so it won't start. I pulled the cold start injector and that seems to not be the problem, I also applied compressed air to the pressure regulator and that sounded like it was opening and closing.. I was wondering what to check next, I heard possible the relay in the glove box area, but after reading more on that I'm not sure if that would cause my injectors to stay open and allow gas through. .
Old Dec 29, 2015 | 07:40 AM
snobdds's Avatar
Test you're cold start injector time switch. There should be the specs around here somewhere. Also test your temp sensor, the one the ECU uses, to see if the computer is thinking your always cold and need more fuel. This is located right next to the time switch under the thermostat.
LucasF249
Feb 23, 2016 12:12 PM
jhsantacruz63
Nov 12, 2015 08:12 PM
SoCal_Todd
Nov 9, 2015 07:02 AM
Mallard
Nov 6, 2015 06:46 AM
CajunFisherman
Oct 17, 2015 06:12 PM
