PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 [153] 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Vavle Lifter Noise Low rpm
  2. heli coil stripped
  3. 5.29s on my 95 V6 4Runner..
  4. Mirror help please
  5. 3VZE Cracked #6 Piston w/pic
  6. Harmonic Balancer Bolt
  7. 90 pickup main bearings and rod bearings
  8. used radiator?
  9. Highflow cat, and cel code 21
  10. turning radius
  11. Tranny Leak in Bellhousing--what seals to replace?
  12. Suffication of white smoke.
  13. no oil pressure 22re
  14. R151 For $750, But Is It An R151
  15. with or without running boards
  16. which connector is used to check FAULTS on 86 22re
  17. Engine Temp Jumping
  18. limited slip rearend for 92 yota pickup
  19. new drums + old shoes = vibration?
  20. rear main seal installations
  21. Opinion needed 4Runner related:)
  22. Crazy vibration
  23. No dash lights
  24. wierd noise??
  25. help ASAP. changing rotors and pads on my 92 4x4. clueless taking apart hub n rotors.
  26. 1995 4Runner Brush Guard help...
  27. Windshield Wash Button CAUGHT ON FIRE!!
  28. O2 sensor wires
  29. '89 truck with 22RE - No power
  30. Bad Wobble At 45mph
  31. Rear drive shaft bolt
  32. help with fuel
  33. Warn rock crawler front bumper on a 4RUNNER!!!
  34. 4Runner running rough.
  35. What are these called?
  36. CV full axle replacement ?
  37. Manual Transmission Fluid
  38. 4x4 5 speed question
  39. 22re code 25 Air/Fuel ratio lean code
  40. Rear window electronic to manual!
  41. Digital dash in action
  42. disgusting valves
  43. 3vz problems
  44. high oil pressure?
  45. 2nd gen jack?
  46. Toyota Long Travel
  47. Radiator boiling
  48. No fuel Pressure
  49. CEL reset: battery vs EFI fuse
  50. 3vz egr help
  51. Exhaust for 94 4x4 SR5 Pickup w/California Emissions?
  52. need a new 22re computer what works?
  53. what's this wire? No place for it.
  54. Help with 1990 Toyota 4 runner Enginge Prob!
  55. leds
  56. towing with a 22RE?
  57. need fuel tank
  58. ford 9inch rear end leaking gear oil still
  59. fuse able links?? 94 pickup
  60. Alternator took a dump
  61. LCE master rebuild kit
  62. My radiator is leaking badly
  63. black canister under hood to the left?
  64. how do I compression test?
  65. Overheating Issues
  66. Got into a fender bender today
  67. 3.0 header solution/problem
  68. forum search = major performance gains 3.0
  69. Any Ideas?
  70. Coolant in my oil
  71. 95 4runner lack of power!!!
  72. 1989 p/u distributor wiring help
  73. Rear cargo cover for first gen?
  74. reasons NOT to weld on sliders? and other slider questions
  75. Coolant entering motor other than HG?
  76. 3VZE TPS & Throttle Stop Screw
  77. 91 pickup 4x4 converted to carb motor
  78. 84 frame on 92 body
  79. 89-95 truck questions
  80. U_Joint problems?
  81. Long Travel IFS or SAS?
  82. Radiator Swap
  83. EGR removal
  84. Broken exhaust, need advice
  85. dash question?
  86. Smelly clutch?
  87. 94 4runner runnin rich, runnin hot!
  88. Homemade Deergaurds
  89. replacing the ac belt
  90. Rear Sag
  91. Bad Rod Bearing
  92. Does not fit models with automatic transmission
  93. Rebuild my stock carb or buy a Weber
  94. Radiator Explosion
  95. 1989 dash replace ?
  96. Long travel shocks
  97. 22re idle surging with A/C on
  98. 22re throwing inconsistent codes
  99. had it with my trailgear springs
  100. Manual tranny swap + bypassing the ADD?
  101. 94 pickup electircal(starting issues)
  102. timing chain jumped
  103. 92 yota race truk questions
  104. Test Drove
  105. Trouble Checking Codes
  106. crankshaft pulley
  107. Lower Nox With Premium Gas?
  108. i need some center console ideas.
  109. Is this a vent tube?
  110. R151F / RF1A rebuild
  111. 90 4X4 22RE clutch replacement
  112. Tailgate Options/ Modifications
  113. Typical 4wd Problem?
  114. Upper control-arm bushing replacement
  115. r134a conversion
  116. cyl 3 not firing
  117. Mounted my air pump and dual battery.
  118. Need help: lost power in low RPMS
  119. Engbldr rebuild kit question!!!!
  120. filter sizes??
  121. 2nd Gen Seats in 1st Gen 4Runner
  122. HELP! Sending unit/switches
  123. Head Gasket saver! tips
  124. 3VZE not sparking & Check Engine light won't come on.
  125. Replace Non-leaking Rear Main Seal?
  126. working on a custom, need some help
  127. 22RE broke a timing chain guide
  128. !st Gen Center Console - Will it fit?
  129. ac condenser mod
  130. Crack in block - possible repairs?
  131. 22RE Engine Idle Problems
  132. Need Help Pulling Ignition Cyl in 92 4runner
  133. 87 4runner sliding window replacement
  134. 93' AFM on an 86' (both 22re)
  135. Cranks, NO START checked everything
  136. Rear bumper question.
  137. 87 22RE engine wiring harness help!!
  138. Drive Shaft/cardan joint angle
  139. shootout at my garage, yota 1 me 0
  140. Replacing Head bolts when rebuilding?
  141. Transmission Problems - sticks in gear
  142. 91 4runner ?'s
  143. Love the 4runner - 1 complaint
  144. what type of exhaust for 3vze
  145. 92 4runner ignition trouble
  146. 22re slight miss at steady engine speed
  147. Renewing tie rods..need help
  148. Tall oil filter .vs. Small oil filter
  149. #1 cylinder trouble
  150. 90 p/u rear end sagging? junk yard help??
  151. Help! Part number?
  152. A/C working better now
  153. im about to paint my truck!
  154. Stripped fitting threads in brand new master cylinder
  155. prime oil pump??
  156. How do you check the fan clutch?
  157. tie rods
  158. How to tell if truck has keyless entry?
  159. What is the "stinger" on off road bumpers for?
  160. Doug Thorley Jardine Cat-back
  161. Liscense plate relocation for MC bumper
  162. V6 auto skipping second?
  163. Interior Dash ??
  164. 3VZE-CEL-Code 71-whats the common problem found?
  165. Fuel pressure reading blues
  166. Denso Oxygen Sensor Part Number - WHAT GIVES!?!?!?
  167. roof rack on 95 4runner
  168. 92 4Runner ( Pic heavy )
  169. #3 cylinder offline (22re)
  170. 2000 tacoma rim fit on 1986 pickup?
  171. Ouch!!! I wonder what happened to my rear end
  172. What to do next.... help
  173. Help guys! 1991 pickup 22re not running right.
  174. Looking for grille guard
  175. HELP! is my truck lifted?
  176. Some pic's of my 86 project coming together.
  177. Wondering if 95 runner rear quarter window glass will fit 2000 runner
  178. Can't get my 89 Toyota started (igniter?)
  179. R150 and R151 - what to look for in a used unit?
  180. low rmp misfire no codes
  181. New tires showed up today.
  182. Oil out the tailpipe
  183. 95 Tacoma Hitch on My 90 Pickup
  184. How to drop oil pan on 1994 4Runner?
  185. 1st gen dash illumination write-up
  186. Quick paint question
  187. Fuel Pump remplacment
  188. starter power problem
  189. Clock Harness
  190. tension on the throttle pulley
  191. Will any year Supra LSD swap into a 92?
  192. Defrost Relay
  193. absorber in rear view mirror ?????
  194. Flat towing a 4Runner
  195. symptoms: losing power on highway especially uphill smelling clutch too. cannot maint
  196. 90 DLX Pickup manual trans oil capacity
  197. Mushy brakes question
  198. 22re Ridge Reamer...?
  199. Leaf spring identification
  200. Best 3vze parts ????????????
  201. How hard to fix an oil pan leak in a 2wd 3vze?
  202. DIY cv Armour Plates?
  203. Do 96 parts fit 95
  204. Lower Intake Manifold Causing Low Idle??
  205. 3.0 sputtering gutless update out of ideas now
  206. Cruise control will not upshift after downshifting
  207. Odd noise coming from airflow sensor
  208. Tell me about 2nd generation 4Runners...
  209. 22re cam bolt
  210. 1989 pickup 4x4 22RE CV Joints
  211. 90 Toyota pickup grey carpet color
  212. H3 xenon bulbs, 55w vs. 100w
  213. Coding like a madman
  214. Ride height?
  215. 3.0 3vze reman troubles HELP!
  216. (new guy) recent reman 3vze long block in 90 4runner, having trouble!
  217. Where can I get an OEM dist cap? Ive searched online but
  218. Need sugestions-93 3vze cam timming
  219. tranny bolts
  220. Update on the truck...(pics)
  221. Brake bleeding problem!
  222. Ok stupid Question Here..
  223. 91 pickup lift and tire sizes
  224. steering stabilizer ?'s
  225. 97 4Runner V6 4WD, white smoke from tail pipe
  226. Replaced the pilot bushing and lever seat
  227. 4" lift with 31's?
  228. pick of stock console
  229. need a pic of a 2nd gen 4Runner underside
  230. 22RE rebuild...Working the Kinks out
  231. Check Engine Light.
  232. My lil project...
  233. Starter Mystery
  234. Engine Rebuild
  235. stupid question about the ac belt
  236. Where can I go with my stock 1990 4x4?
  237. Obscene timing?
  238. 91 4R fixer
  239. re-use head gasket?
  240. Different Gen Parts Swap?
  241. 22 R-E engine question, is it time for a new one.
  242. Noob with 1986 toyota 4x4 manual
  243. Which Headers for a 3.0L
  244. gas spraying out of the upper intake manifold
  245. OME 900 and Ranch 5000 shocks?
  246. 22R gurus (Pre 84 vs post 84)
  247. Temp. gauge needle drops when I turn A/C on?
  248. Dash Pot??
  249. Pickup Rear Sliding Glass
  250. overheating help
