#1 cylinder trouble
Old Aug 27, 2009 | 08:34 PM
whitebullet3's Avatar
#1 cylinder trouble
when I pull spark plug wire off of cylinder one there's no change. Injector is popping off, fire on the plug with it out, but something isn't right ?
Old Aug 27, 2009 | 09:16 PM
bump guys come on
Old Aug 27, 2009 | 09:45 PM
abecedarian's Avatar
It's usually common courtesy to wait 24 hours before bumping a post. Considering that it appears to be a hot topic for you, I'm going to assume you have searched the forums, even using Google to help, right? If you didn't take that time for that, rest assured there are plenty of search results and such from Yotatech and Google telling you what you should check if you pull a plug wire and the idle doesn't change.
Old Aug 28, 2009 | 02:38 AM
TNRabbit's Avatar
Well if you have fire & fuel, you're missing compression and/or air. Broken valve spring/stuck valve?
Old Aug 28, 2009 | 08:50 AM
yeah ive searched over and over
4.34runner88
Feb 7, 2016 02:24 AM
Boomer8404
Sep 10, 2015 09:01 AM
old87yota
Sep 9, 2015 12:39 PM
Squigglez
Sep 4, 2015 07:33 AM
128keaton
Sep 3, 2015 05:09 PM
