Starter Mystery
Old Aug 24, 2009 | 07:47 PM
owenwalk's Avatar
Starter Mystery
I just replaced my old starter with a brand new oem starter after having to push start the truck a couple of times too many. After long drives it would not start, it would just click. Push starting it would seem to get it working again till the next long drive. Now the new one is doing the same thing. What else could it be? Seems pretty unlikely the new starter is bad.
Old Aug 24, 2009 | 07:57 PM
LITLRED's Avatar
How about a few more details about your ride. Year, engine, manual I assume since you can push start it.
Old Aug 24, 2009 | 08:00 PM
RobD's Avatar
It sounds like it could be heat soak. This is common with engines that are high horsepower (not likely with our trucks) or have headers close by, etc, where the starter gets too hot.
You might be able to solve it with a heat shield. Just my two cents.
Old Aug 24, 2009 | 08:01 PM
owenwalk's Avatar
Oh yeah, minor detail. 87 Runner, manual 5 speed, 22re, the usual stuff...
Old Aug 24, 2009 | 08:03 PM
owenwalk's Avatar
It does have header but wrong side. I also wondered about the heat, but it did it one evening after driving only 10 miles.
Old Aug 24, 2009 | 08:05 PM
pb4ugotobed's Avatar
Check for a voltage drop from the wire going from battery to starter. There's probably a lot of resistance in there somewhere... loose connection, something corroded, etc that's amplified by the head of running your truck for a while, because heat will only add resistance to a circuit. That's probably where I would start
Old Aug 24, 2009 | 08:12 PM
bugs1961's Avatar
Yea, and the ground side too. If you have original battery cables, I would replace them. Corrosion in the cables may not be visible under the insulation. A weak battery may also cause the symptoms. Like PB4... said, a hot starter requires more current to operate and problems in the electrical circuit makes it worse.
Old Aug 24, 2009 | 08:18 PM
owenwalk's Avatar
So you are saying to check the voltage to the starter now while it is working and it should read something around 12 volts, and next time it acts up, it may read lower. That could be, but when it happens, and after I push start it, then the starter works fine, and the wiring would still be at the same temp...
Old Aug 24, 2009 | 08:19 PM
RMA's Avatar
RMA
Yea Id go with the wires , maybe loose or more than likely corroded ..
Old Aug 24, 2009 | 08:29 PM
owenwalk's Avatar
OK, let me check that out. Thanks Guys.
Old Aug 24, 2009 | 11:28 PM
wyoming9's Avatar
Red face
i upgrade to number 1 welding cable that I can get the cut off ends from damaged cables .
I then crimp on the ends and install the cables. I use Deka Marine terminals which have a stud and wing nut. They are also pretty cheap less than $5.00 a set . even lets say at a $1.00 a lug terminal lets say 3 grounds and one positive that would be 8 crimp on lugs . so for less than $15.00 I can upgrade one vehicle.
if you are having starting problems you can even run a new ground cable right to the bottom starter bolt
This has cured no end of charging and starting problems.
Old Sep 2, 2009 | 08:14 PM
owenwalk's Avatar
Problem solved. I cleaned and tightened all connections (which looked ok) and so far, after several long trips, she starts everytime. Thanks everyone.
ladybugRC
458
Aug 21, 2020 10:41 AM
nvwiggins
13
Jun 16, 2016 03:05 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
