r134a conversion
Old Aug 29, 2009 | 11:41 AM
whutface's Avatar
r134a conversion
Would you just use a regular r12 compressor if your converting to 134a?
Old Aug 29, 2009 | 03:32 PM
turborich's Avatar
Yes sir. You will need to add the proper amount of 134a & compatible oil. If you buy a retro fit kit then you should be good to go. Make sure not to overcharge it as 134a runs at higher pressures than r-12. It would be a very good idea to vacuum (pump down the system before you add the new refrigerant) If you have access to a pump.
justdifferentials
14
Jun 11, 2017 08:36 PM
live4soccer7
May 11, 2016 06:52 PM
runnermedic
13
Sep 21, 2015 05:20 PM
highonpottery
Sep 14, 2015 12:46 AM
