3vz problems
Old Sep 1, 2009 | 07:30 PM
just call me smithy's Avatar
3vz problems
hay im looking for some help with my 91 4runner 4x4 3vz 3.slow, hears whats wrong it seams to realy idols ruff only when im in gear and if im at a stop light idoling it will bog out and die,but if im in park or nutral it will idol just fine, the last fix i did on my 4runner was new plugs and new cap with rotor please help.................... also i know the 3vz dosent brake eny speed bariors but it feels way under powerd when i ecelerate.
Old Sep 1, 2009 | 07:35 PM
jpmountainboy's Avatar
I would start by checking your timing...did it happen right after you changed you cap and rotor or just slowly get worse?
Old Sep 1, 2009 | 07:36 PM
slowly got worse
Old Sep 1, 2009 | 07:37 PM
id also make sure those new wires clamped onto the sparks well. they kinda click when they do. when i changed mine i had to physically push the new wire terminal further into the big rubber insulator that plugs onto the plug...that way I could for sure feel them click on well and then pushed the rubber insulator back down on the plug.
Old Sep 1, 2009 | 07:41 PM
if it were the wires why would it only idol ruff when im in gear?
Old Sep 1, 2009 | 07:42 PM
200 to 100 when in drive 800 when in N or P
"but if im in park or nutral it will idol just fine" somehow i didnt see this the first time this points to other things. It would seem clutch related and I do not have a auto so I probably wont be much help.
however...if it idled better with just a little bit of gas peddle, i might start to suspect fuel filter starting to clog.
Old Sep 1, 2009 | 07:43 PM
torque converter?
Old Sep 1, 2009 | 07:45 PM
ya i have an auto ,wich has given me a bit of truble a few months ago but not latly
Old Sep 1, 2009 | 07:50 PM
yeah cause when you put it in gear the torque converter actually puts some pull on the engine even without depressing the gas...so if the gas was a little restricted (and usually slowly gets worse in the filter) I could imagine how maybe a restricted filter might not allow it to get enough gas to pull the vehicle in gear.
I dont know...just bouncing ideas around.
Old Sep 1, 2009 | 07:53 PM
fuel filter,u mean to tell me im wasting all my money on 91oct gas
Old Sep 1, 2009 | 07:55 PM
what about the injectors? could they be durty?
Old Sep 1, 2009 | 08:30 PM
any one?
Old Sep 1, 2009 | 09:50 PM
we should all be replacing our filters if we havnt anyways so you could try it for 15$ and at least you would be doing something you should anyways even if it doesnt do anything.
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
kyletbert
Jul 17, 2015 11:39 AM
