94 pickup electircal(starting issues)
Old Aug 30, 2009 | 12:29 AM
4gen5thtime's Avatar
I have a 94 toyota pickup. It has no power to the turn signals, wipers, starter, or guages. When I got it I was told it needed a ign. switch, I did the tests on it and it was not holding continuity(checked the toyota factory manual to test it). I bought a new switch and installed it and still not working. I've checked all my fuses, did a few tests on my ecu(that couldnt be it becuase the truck runs perfect when its bump started). So what wires would this be that I should check for my problem. I thought it was the switch but I checked this new one and it checks out fine I even had a shop run a test to see to. I'm thinking its a ground but what one would cause all of this, and still let the truck run great(22re so its efi). Please help I wanna get my truck going I hate bump starting it, not knowing how fast I'm driving, no turn signals, or radio kinda sucks and no wipers on the coast is bad.
Im getting power to ign1 and ign2 on the starter switch. Nothing to acc. I'm trying to figure out what is my ground on the ign switch but the tfsm(toyota factory service manual) is not super discritive on this. Any input on the grounding? Or fuseable links?
Thank you so much for your help.
Wil
Old Aug 30, 2009 | 10:56 AM
So I'm getting power in the fuse block to am2 but not to am1. Were would be the fusable link for this? I'm checking power with the ign switch in the "on" position and by pulling the "big" fuse's and testing power between the terminals. Thanks for any help.
Old Aug 31, 2009 | 07:33 AM
any one got anything on this??? I've searched and searched with nothing coming up..
Old Sep 1, 2009 | 09:48 PM
So I checked all the ones I know of, the 30amp the 40 amp and the 80 amp in the fuse box. And I also checked the wire going from the battery to the fuse box. What other ones are there? My truck is not getting any power to anything other then the head and tail lights and hazards. I have to push start it and it runs great but still only power to headlights and tail lights and hazards. I'm lost...
Old Sep 1, 2009 | 10:14 PM
malteserunner's Avatar
Check for corrosion or loose plugs on the back side of the fuse block in the driver side kick panel. Also check the grounds in the vicinity of the same fuse block.
Old Sep 1, 2009 | 10:19 PM
I've checked all my grounds, Hell I pulled the bed today and checked the grounds under that. There is no corrosion or loose plugs on the fuse box. the ecu is hooked up to.
Old Sep 1, 2009 | 10:39 PM
raydouble's Avatar
Try this one
http://www.ncttora.com/fsm/1990-1995...5/contents.htm
Should be mostly the same electrically and is much more in depth than the 93 pickup FSM.
Old Sep 1, 2009 | 10:53 PM
thanks thats burl. I'll post back with what I find out...
Old Sep 2, 2009 | 09:15 PM
Nothin as of today. Just voltage checks and all that bs. I posted asking if any one knows of a good toyota mechanic in my area on c/l and with in a hour I had a email from a guy. He works at a toyota dealer and I told him my issue and he said its the plug going in to the firewall on the pass side. I will redo all the wires and go from there. Cross fingers guys. I wanna get started on lifting and doing a sas and droping in a tcase and stuff but its gotta be running to carry axles home...
Old Sep 2, 2009 | 10:19 PM
Damn that wasnt it. Oh well I guess I'm calling the guy and for $15 an hour he will fix it. Ehh....
Old Sep 4, 2009 | 05:06 PM
hah funds went away for this week, I locked keys in the truck and it was $75 to get a key man to come out. errrr.... but i got a free tool made by them so if it happens again I'm set.
Old Sep 8, 2009 | 09:31 PM
Got her running today. Thanks to a whole new harness. I gave up on tracing wires and stuff. so I replaced my whole engine harness got one from a pnp yard for $30. Then today I heard oregon is outlawing sas so time to move...
Crazychris1871
Jun 27, 2016 10:38 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
serenity03k64
Jun 27, 2015 07:59 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
