93 toyota
Old Aug 23, 2009 | 04:42 PM
kixx's Avatar
93 toyota
this is my fourth toy ,it is 93 ,auto 4x4 3.0 ,just got it about 2 weeks ago ,check fuel mileage ,to day 10.1 ,what is that ,has 3 inch suppenision lift ,with 33 12.50 mt ,would like to get it up to about 17 or 18 mpg help me out whats wrong where do I start with the tire the lift ?10 made me sick wanted to sell it after that ,thanks for any help
Old Aug 23, 2009 | 05:16 PM
ltgvolsrock1's Avatar
it could be a # of things first off check the air, and the fuel filter. check your tire pres. ive never owned a 3.0 but ive heard that they like gas alot! good luck
Old Aug 23, 2009 | 05:59 PM
MuddinRI's Avatar
I own a 1994 auto 3.slow with 32" on it and it was getting about that for mileage when i picked it up. Try a full tune up fuel filter,air, etc make sure the alignment is close or that will burn the petro. you might want to check the timing for giggles.
Old Aug 23, 2009 | 08:31 PM
1990mudslut's Avatar
Nah don't waste money on a tune up that is not the problem.I have 90 3.0 auto with 3inch body lift and 33x12.5s.The stock gearing in our trucks is made for 28 inch tires or smaller!!!You have to re gear if you wanna see gas mileage I get like 10-12mpg on the stock 4.10 gears my truck runs at 2500 rpms in 3rd gear at 60 mph.I have bought a set of 5.29 gears for the rear end and this will bring my rpms back up and give me back all the power lost in acceleration and should give me a minimum of 17 mpg.
regearing is relatively expensive so gl.
Old Aug 23, 2009 | 09:13 PM
Stuwy123's Avatar
Check inside your driver's side door frame.
Looks at the bottom right hand corner. It will say something like G292, G284 or G254.
Tell us what you find.
I'm guessing you have G284, which means a 4.3:1 diff ratio. You will need at least a 4.88 with an auto with 33" tires.
Old Aug 23, 2009 | 09:24 PM
he will still be under geared at 4.88.5.29 is the gearing he needs
Old Aug 23, 2009 | 09:33 PM
Tofer's Avatar
Sponsor
hummm 3.0 + auto + 33s = 10mpg..... yep sounds about right.
Old Aug 23, 2009 | 10:06 PM
seanmearse's Avatar
When I had the Runner, it was on 33's, 4.30's, 5 speed. I could make the trip from ridgecrest to big bear, 70-75 all the way, still get around 14-15. Ask anyone on here in cali how bad the 18 from lucerne is. Here are the stats on that truck.
94
K&N air and oil filters
Royal purple engine, trans, t-case and diff's
E3 plugs
Magnaflow Muffler
Now, if it had 4.88's, more than likely would have pulled 19-20. So, 4.88's.
EDIT- and who knows when the last tune-up was performed on this truck? Just picked up my 84, drove her for a week, did a complete tune-up, made a world of difference. I dont think the PO of this truck did anything, runs great now.
Old Aug 23, 2009 | 10:08 PM
Jay351's Avatar
Throw some 5.29's into your diffs, that will put you just past stock in terms of gearing.
I have 4.88's wich match my 33's and 5sp perfect. I have gotten as high as 21mpg on the hwy Not bad for a lifted truck!
Old Aug 24, 2009 | 06:25 PM
kixx's Avatar
what if I was to drop to a 31 10.50 tires on it what gear ratio would I need and how does changeing gear ratio afect the speedometer will look at the door tom. to see what it says ,and also what does it cost to change gear ratio ,I can do some basics but no mechanic,thanks for the help ,
Old Aug 25, 2009 | 05:51 PM
kixx's Avatar
back to top
Old Aug 25, 2009 | 05:58 PM
If you drop to 31s you will need a 4.88 ratio with your automatic.I would stick with 33s and just buy some 5.29s.However if you are not mechanically inclined at all look at 1k a axle max.
Old Aug 25, 2009 | 06:06 PM
kixx's Avatar
so 2 grand ?,would it be cheaper to have the kit taken back off and pupt to stock ?,love the truck ,but I coon hunt all over and need some miles on a take of gas ,who would put them gears in a tranny shop ?
Old Aug 25, 2009 | 06:38 PM
If you start reading up on differentials and the whole ifs the diffs are rather easy to swap out and would save you a ton of money!You can do front and rear for about a grand maybe a little more If you install the third members back into the differentials your self instead of paying a shop to do it.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
