Fuel pressure reading blues
Old Aug 27, 2009 | 12:23 PM
buckz6319's Avatar
Old Aug 27, 2009 | 01:24 PM
buckz6319's Avatar
thought I would
Old Aug 27, 2009 | 06:13 PM
abecedarian's Avatar
High fuel pressure can cause a rich mixture, misfiring, etc. Might trigger a CEL code for fuel mixture rich, meaning the ECU has tried leaning the mixture out and has reached the end of its adjustments (fuel trim settings).
Since the fuel flow hits the filter first, you can safely rule that out. Considering the FPR is adjusting the fuel pressure according to vacuum applied to it, that suggests the regulator is operating. This implies pressure is being held high by a restriction downstream: corrosion or other restriction in the return line from the engine to the tank, maybe even a pinched line.
Old Aug 28, 2009 | 08:17 AM
buckz6319's Avatar
Old Aug 29, 2009 | 04:50 PM
buckz6319's Avatar
Old Aug 29, 2009 | 05:18 PM
86tuning's Avatar
what exactly are you trying to repair?
how do you KNOW FOR CERTAIN that your pressure gauge is accurate?
Old Aug 29, 2009 | 06:18 PM
buckz6319's Avatar
Old Aug 30, 2009 | 11:27 PM
86tuning's Avatar
I wouldn't worry about your fuel pressure, if your emissions are okay. 10-20% more pressure isn't something that I would spend time chasing.
However, driveline vibrations can be tricky to pinpoint.
What's the mileage of your vehicle?
When did this vibration start?
What rpm does it occur?
In gear or in neutral? In what gear? At what vehicle speed?
Old Aug 31, 2009 | 02:35 AM
buckz6319's Avatar
Old Sep 1, 2009 | 08:53 AM
86tuning's Avatar
Did you try any Toyota dealerships? I'll read your threads when I get a few minutes.
Cheers.
Old Sep 1, 2009 | 01:57 PM
buckz6319's Avatar
jbv808
Aug 6, 2021 04:47 PM
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
