clutch master cylinder problem!!
Old Aug 23, 2009 | 03:07 PM
LilPyke's Avatar
ok so i replaced my master cylinder for my clutch and no i have no pressure in it... how do i get pressure built back up cause its not building up and all the bolts are tight so its not leakin fluid.... any help??
Old Aug 23, 2009 | 03:27 PM
myyota's Avatar
I had the same problem on my 86 4Runner a while back, so i just went ahead and replaced the clutch master cylinder and slave cylinder, it was less than 50.00 dollars at Napa so i did both, everything was good after that, so you might need to replace the slave cylinder also.
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
