ECM Failures
Old Aug 23, 2009 | 05:29 PM
mac9968's Avatar
ECM Failures
Has anyone ever replaced their ECM? How often do they fail? Is it likely to fail and have zero codes generated, or visversa, tons of codes all over.
Old Aug 23, 2009 | 05:41 PM
scuba's Avatar
Turn the key to on, if your cel is there then the ECM is alive. If not start looking for a new one.
Old Aug 23, 2009 | 06:06 PM
abecedarian's Avatar
Why start looking for a new one?
Old Aug 23, 2009 | 06:17 PM
scuba's Avatar
If the cel isn't on with the ign in on wouldn't that indicate the ECM is dead?
Old Aug 23, 2009 | 06:31 PM
Yeah, maybe... if you're sure the ignition switch is working too.
Old Aug 23, 2009 | 08:30 PM
bugs1961's Avatar
In 25 years of working on Toyota's I've never heard of an ECM failing all by itself. It usually takes an electrical mistake by someone that causes it to fry.
The CEL will be inop if the EFI relay has failed. Or the bulb is burned out. Or a wiring issue. The FSM has a trouble shooting section on the ECM that will take you through tests to determine what the problem is. Go through that before replacing an expensive ECM.
Old Aug 24, 2009 | 03:02 AM
TNRabbit's Avatar
ECU failures have occurred but they're VERY infrequent. I'd check for other issues first.
Old Aug 25, 2009 | 09:29 AM
mac9968's Avatar
Thanks, I think I found other issues (inline fuel filter). Thanks all for the posts. I dont believe I am looking at ECU failure.
Old Aug 25, 2009 | 04:17 PM
Flash319's Avatar
I have had 2 ECU's with holes rotted in the sides of them and full of salt and water. They work fine. The ECU's in these trucks are very dumb and do not have much in them. Like was said, human error blowing them (still hard to do as most of it is protected with the efi fuse) or 1 in 10 million component failure.
moparbay
Mar 10, 2023 03:50 PM
Rcbc92
Sep 26, 2015 03:00 PM
Gone Fission
Sep 22, 2015 04:51 AM
_Nicco_
Sep 21, 2015 03:06 PM
ErikZ1220
Sep 10, 2015 04:53 AM
